Old 27th Dec 2016, 12:29 pm   #81
indigo.girl
Default Re: My first valve radio project - Philips 462A
Well, the rectifier heaters light up but very faintly compared to the other valves in the set. The voltage across the heater is only 2V rather than the expected 4V. The continuity of the heater is OK with resistance just 2 OHMS. So, apart from the voltage across the heater being a bit low the rest seem ok.
indigo.girl is offline
Old 27th Dec 2016, 12:31 pm   #82
indigo.girl
Originally Posted by crackle View Post
Is the transformer hot or cool after an hour of being on with no valve heater load?
Hi Mike - I was too impatient to wait a full hour but after a while, say 30 mins, the transformer was mildly warm, certainly not hot to touch, but not 'cold as metal either'. I have it on again now with no load to test properly if needed.
Old 27th Dec 2016, 12:40 pm   #83
GeoffK
If you remove the rectifier valve from the valve holder and then measure the heater connections in the valve holder what what is the A.C. voltage.
As it won't have the superimposed rectified DC voltage it should measure the 4 Volts A.C.
Though EXTREME caution is need if this is carried out as the transformer anode connections will be at the peak high tension secondary voltage of over 300 Volt A.C.
It could be that the rectifier valve has a partial short circuit.
It might be useful if you took a few pictures of the work you have carried out, what type of capacitors where fitted as the main smoother and reservoir.
With all valves removed the heater voltage to the other valve holders and pilot bulbs should be 6.3 Volts A.C.
GeoffK is offline
Old 27th Dec 2016, 12:48 pm   #84
ms660
ms660's Avatar
Also with the rectifier fitted measure the DC voltage across C26 that should be consistent with the rectifier symptoms already observed...Just to get the whole picture.
Lawrence.
ms660 is offline
Old 27th Dec 2016, 1:40 pm   #85
indigo.girl
With all the valves removed I can measure 2-3V AC across the base for pins 2 & 8 of AZ31 (for rectifier heater) and 5 VAC across the bases for pins 1 & 8 for all the other valves. There is also 5VAC across the pilot bulbs.
There is no voltage measurable across C26.
Here are come photos of my work so far: please excuse the colour of the green & yellow wire coverings that I have used to insulate the bare legs of the capacitors. All I had available...
ID:	134971   Click image for larger version
ID:	134972   Click image for larger version
ID:	134973   Click image for larger version
Old 27th Dec 2016, 1:41 pm   #86
indigo.girl
Now been on 1 hour+ . Transformer is warm to touch but not hot. All seems ok.
Old 27th Dec 2016, 1:48 pm   #87
Station X
Station X's Avatar
This radio has complex voltage selector arrangements for the mains transformer primary. Is the selector "disc" correctly to make the appropriate connections for your mains voltage?
Graham. Forum Moderator
Station X is offline
Old 27th Dec 2016, 1:59 pm   #88
indigo.girl
Hi Graham - As far as I know yes.
ID:	134975   Click image for larger version
Old 27th Dec 2016, 2:18 pm   #89
Station X
Station X's Avatar
I agree that the disc is correctly placed for a 245V supply. I was just wondering whether the wire links within the disc itself were correctly placed.
WITH THE VALVES OUT, you could check the heater voltages with the disc set to 220V and 200V to see if they are higher.
Old 27th Dec 2016, 2:32 pm   #90
Argus25
No Longer a Member
For the low range pF capacitors (usually 3pF to 3000pF range), if you have to replace them, such as ones that get damaged ,fail, or removed by mistake, these are always better replaced with 500V silver mica types. These usually have a dark brown look. The better quality ones are the American mil spec types, if you use these you will never have any trouble again, especially in a domestic tube radio where the voltages are generally nowhere near 500v. Here is a typical one on UK ebay:
http://www.ebay.co.uk/itm/CAP-SILVER...wAAOxyaTxTPxin
There are some cheaper 330pF Sangamo ones that are also good on ebay. Last time I looked RS components also stocked a range of 500V silver mica caps which are very good. (any capacitors on the mains power side of the transformer need special ratings like X2 types)
Don't be upset with the occasional mistake along the radio restoration trail, by the time you have restored a few radios you will have mastered the art.
I would be cautious with the 330V electrolytics, since when the set hasn't warmed up the voltage could easily go to 300v x 1.4 , so 450V electrolytics might be better, but if the peak voltage is only 300V its probably ok.
Argus25 is offline
Old 27th Dec 2016, 2:34 pm   #91
indigo.girl
Well here's an interesting result!
At 245V I get 2-3V AC and 5 VAC across the heaters of AZ31 and EBL21
At 220V I get 3V AC and 6 VAC
At 200V I get 3-4 VAC and 6 VAC which matches the valve specs
So I do seem to get a higher transformer output when a lower voltage is supplied
I moved the disc to 145V and something made a vibrating/humming noise so I pulled it straight out (same for 125V and 110V)
With the 200V disc setting giving me valve spec values I checked for HT output from the EBL21 anode (pin 2 to chassis) but ZERO HT DC voltage :-(. The valves are illuminating nicely at this 200V setting - in all cases though the rectifier is much less bright than the other (I guess to be expected because heaters are only powered by 4 not 6 V AC.)
Old 27th Dec 2016, 2:51 pm   #92
indigo.girl
Yes, I thought the 330V max working voltage of the electrolytics sounded low compared to the advice on this thread of always going for a 630V for all caps to be sure. The 330V electrolytic was the spec used previously and on the trader service data. Were higher voltage caps more difficult to obtain back in the 70s?
Old 27th Dec 2016, 2:51 pm   #93
GeoffK
The radio might have looked better if you had just put the smoothing and reservoir capacitors underneath the radio, and saved a lot of work.
From the experiments with the voltage tap it could be there is a 'shorted turn' in the primary of the mains transformer and putting the tap on 200V is boosting the winding as 240Volts is being applied to the 200 Volts setting, but if this is the case then it is not a good condition for the transformer to operate at.
The lower tapping settings definitely should not be used, the vibration is because of severe overload.
GeoffK is offline
Old 27th Dec 2016, 3:04 pm   #94
indigo.girl
Ah, I see - in all cases 240V is being applied to the transformer each time (being the UK supply from the mains) and the disc position denotes the ideal place for the supply voltage to be added across the transformer depending on the mains supply you have. This should normally be the 245V position for UK. When I move the dial to the 200V setting 240V is still being applied across the transformer windings but across fewer of them, and perhaps bypassing a shorted turn, hence a better output. In the case when I set the dial to 145V this means I am putting the 240V across an even smaller section of the windings and hence over load and vibration.
Old 27th Dec 2016, 3:07 pm   #95
Station X
Station X's Avatar
Assuming that everything we've been told is true, I think we're reaching the inevitable conclusion that the mains transformer is faulty.
You could try selecting the 220V setting, inserting the rectifier, checking the on load heater voltage on the rectifier and if OK checking the HT voltage across the smoothers.
This isn't a long term solution though.
Old 27th Dec 2016, 3:23 pm   #96
indigo.girl
Hi Graham - at 220V setting I still get no HT voltage measureable across the smoother capacitor C26. I'm measuring across the two tails of the C26 itself or from pin2 of AZ31 to chassis. So does this mean that I have a faulty mains transformer AND a faulty rectifier?
(I get 310 VAC from either anode to chassis - pins 4 or 6 to chassis on AZ31)
Old 27th Dec 2016, 3:24 pm   #97
GeoffK
Should be pointed out that the rectifier valve is meant to operate from the separate isolated 4 Volt winding so will light with the same level of brightness at 4 Volts as the other Valves at 6.3 Volts.
With the rectifier removed there will be no D.C. high tension voltage with the 4 Volts A.C. voltage that is there to light the rectifier heater.
GeoffK is offline
Old 27th Dec 2016, 3:39 pm   #98
indigo.girl
So no DC voltage from chassis to pin 7 of the rectifier?
Which pin on the rectifier?
I get measure 345V on DC settings on my mulitmeter between the anode pin 4 and chassis (same as anode pin 6 and chassis). I get 310V on AC setting on multimeter.
Old 27th Dec 2016, 3:43 pm   #99
Station X
Station X's Avatar
Sorry. I meant chassis to pin 2 or 8 of the rectifier.
Old 27th Dec 2016, 3:50 pm   #100
Station X
Station X's Avatar
If still no HT, check that R2 and R3 (manufacturers sheet) aren't open circuit.
