Old 10th Oct 2019, 11:04 am   #1
Eagles123
Location: East Kilbride, South Lanarkshire, Scotland, UK.
Default How to fit a pilot light to a Philips NG5155 amplifier?
Hi all,
Long time lurker, first time poster here.
So, I aquired a NG5155 valve record player. All working fine, the electrics had all been modernised with new resistors and capacitors etc but the casing and turntable was damaged beyond repair.
I removed the electrical section and will rehouse and adapt it to use as an mp3/turntable amplifier.
The original record player never had a bulb to show whether it was on or off - I would like to fit one, but am unsure the easiest and safest way to do it.
I was thinking of using the on/off switch pot lugs to attach it to - am I on the right lines ?
I think I'd rather have a bulb with 'jewel cover' unit (like a guitar amp) than an LED.
Any help would be gratefully appreciated, thanks
Eagles123 is offline
Old 10th Oct 2019, 11:21 am   #2
AC/HL
AC/HL's Avatar
Default Re: How to fit a pilot light to a Philips NG5155 amplifier?
The safest way would be to use a 6.3v filament bulb wired across the valve heaters, but a mains neon as you suggest will be OK.
THe circuit is the same as the NG5055: https://www.service-data.com/section.php/6168/1/ng5055
AC/HL is offline
Old 10th Oct 2019, 2:15 pm   #3
Some odd "Philipsisms" in the amplifier- volume controls have some odd frequency shaping and whilst there're bias resistors for each output valve, they're in parallel with a single bypass capacitor
Maybe two small resistors were cheaper than one big one?
Herald1360 is offline
Old 10th Oct 2019, 2:35 pm   #4
Oldcodger
Not exactly in keeping with old practices, but a novel way of providing an on/off indication if it does not look out of place is to use a LED with a reverse diode and a capacitor to drop volts. But if using a 6v hater supply I'd use a reverse diode on the LED and a 600 ohm 1/4 watt resistor ( IF my maths are right), as using the standard method of using a capacitor would need one circa 5F. Where as ( again if my maths are right, using a cap and mains would need a 0.5 uF cap).
Oldcodger is offline
Old 10th Oct 2019, 5:27 pm   #5
AC/HL
AC/HL's Avatar
The OP doesn't want an LED though.
Item 3 here is the classic: https://mullard.org/collections/comp...-lights/bulgin
AC/HL is offline
Old 14th Oct 2019, 12:36 am   #6
Eagles123
Hi there,
Apologies for not getting back sooner. Thank you all for the help and information, it
was greatly appreciated.
