Old 10th Jan 2019, 2:00 pm   #1
NorfolkDaveUK
Default Sony TC-458 not changing speed .
As per the title . I`m finding this one difficult to track down if anyone has any idea ?
I`ve had the switch out and cleaned it , the transistor Q901 is supposed to have 80v at the collector , but it only has 20v but i cant figure out why , as always any help you can give will be greatly appreciated..
NorfolkDaveUK is offline
Old 10th Jan 2019, 2:34 pm   #2
ms660
ms660's Avatar
Default Re: Sony TC-458 not changing speed .
Presumably that's 20 volts WRT the servo ground and not the main signal ground ?
Lawrence.
ms660 is offline
Old 10th Jan 2019, 2:53 pm   #3
NorfolkDaveUK
I`m not sure what you mean Lawrence , sorry for the ignorance . I followed the schematic , read the voltages to reference to ground .
Old 10th Jan 2019, 2:55 pm   #4
NorfolkDaveUK
In forward play mode . Pins one through seven on the IC have the correct voltages , but eight through fourteen dont .
Old 10th Jan 2019, 3:08 pm   #5
ms660
ms660's Avatar
No problem, I was just pointing out that the servo ground ref. is separate from the main signal ground ref.
Lawrence.
ms660 is offline
Old 10th Jan 2019, 3:12 pm   #6
NorfolkDaveUK
The motor seems to be working fine . Someone had put the flippin voltage selector in wrong (because the sticker had fallen off) so it was doing all kinds of weird stuff then I got it . I sorted that out , removed the switch and cleaned it , but still there is no 3.75 speed , its just stuck on 7.5. Its a bit weird this machine as it has little power supplied all over the place . Where is the servo ground ref then please ?
Old 10th Jan 2019, 3:21 pm   #7
ms660
ms660's Avatar
It's shown on the schematic I'm looking at..."Servo Control Ground Line" Eg: Pin 12 of the servo IC.
Maybe report the voltages you can measure WRT the above ground line for all the IC pins and all Q901 connections?
Lawrence.
ms660 is offline
Old 10th Jan 2019, 3:44 pm   #8
NorfolkDaveUK
OK measurements taken in FWD play mode :
1 - 4.56
2 - 0v
3 - 0.5v
4 - 1.9v
5 - 7.86v
6 - 8.57v
7 - 14.5v
8 - 14.7v
9 - 0.6v
10 - 0v......(fault)
11 - 0v .....(fault)
12 - gnd ref
13 - 0.14v
14 - 0.14v
C : 20.25v
B : 0.23v
E : 0.69v
Chip is borked isnt it . 10 and 11 are output pins .
I was using pin 2 when I did the measurements before by the way so the results are the same . I dont use the chassis . unless i need too .
Old 10th Jan 2019, 3:50 pm   #9
ms660
ms660's Avatar
What speed is it actually playing back at?
Lawrence.
ms660 is offline
Old 10th Jan 2019, 3:55 pm   #10
NorfolkDaveUK
Its going wild at the minute Lawrence because the tension is all over the place .
Old 10th Jan 2019, 4:01 pm   #11
NorfolkDaveUK
pins 10 and 11 of the IC are the output from the inverter so its going to be messing with everything isnt it . Bit of a nuisance but there is one board on Ebay , its in the states but hey ho . The chip is a Sony special so I guess it`s going to have to do .
Old 10th Jan 2019, 4:23 pm   #12
NorfolkDaveUK
Sorry 11 is the output from the inverter , not too sure what 10 is , it looks like its driving the transistor no ?
Old 10th Jan 2019, 4:28 pm   #13
ms660
ms660's Avatar
It might be worth checking the transistor and the diode bridge as well.
Lawrence.
ms660 is offline
Old 10th Jan 2019, 4:33 pm   #14
NorfolkDaveUK
The transistor is coming up good , about to pull the the bridge .
Old 10th Jan 2019, 4:41 pm   #15
NorfolkDaveUK
Bridge is good . re-capped the board . still nothing so that only leaves resistors and the IC
Old 10th Jan 2019, 4:48 pm   #16
NorfolkDaveUK
Well at least I got to the bottom of it so thats a win by all accounts mate (thanks as always for your assistance its always treasured thank you) I will order the new board and wait . Thanks .
Old 10th Jan 2019, 6:56 pm   #17
ms660
ms660's Avatar
Good luck with it, by the way I don't know if the manual you have has a circuit description for the servo motor control, the copy of the manual I have doesn't but there's a very good circuit explanation given in the Sony TC-440 manual that's available from the vintageshifi site if you have not got the circuit description and need to do any final eliminations.
That servo IC and circuit arrangement was used in quite a few models.
Lawrence.
ms660 is offline
Old 10th Jan 2019, 9:39 pm   #18
NorfolkDaveUK
Thanks Lawrence , I`ve ordered a new board and moved on now bud I`m pretty sure it can`t be anything else but the IC . I`ve checked every componant on the board and the only discrepancy are those 2 pins , but I will down load the manual you suggest , the one for the 458 is pretty poor to be fair.
Thanks mate.
Old 11th Jan 2019, 4:53 pm   #19
8 Tracker
8 Tracker's Avatar
Before you give up and wait for the new board to arrive, check the motor. I had one of these models drive me round the bend with a speed control fault. I changed the IC and it made no difference at all. The motor has a separate disc on it which provides feedback to the control board via a sensor next to the disc. This disc was loose on the motor shaft, so the speed control was all over the place. You need to take out the motor to check it, but it may be worth a try.
Mark.
8 Tracker is offline
Old 15th Jan 2019, 2:36 pm   #20
NorfolkDaveUK
Many thanks for that . I wont give up , thats for sure and I`ll try your suggestion . I just replaced the IC and as you say its made diddly squat difference so thats £30 wasted ..haha . I did only pay £40 for the machine though so we arent done yet .
I dont have a speed "all over the place " issue though , i just have no speed change at all . I will check the motor and have a look and see if that sensor is the problem . The q901 transistor with very low voltage is whats making me think its more likely to be a power issue though .
Many thanks .
If anyone else has any suggestions I`m more than happy to listen and try them out . Would be great to get this one back from the brink !
