9th Jan 2019, 3:54 pm | #1 |
Mains power cable for Philips N2204
Hi all,
I am seraching for a mains cable for a vintage philips cassette recorder N2204, does anyone know the name of this type of plug so that I can hunt one down ? Thanks. Pete. |
9th Jan 2019, 6:24 pm | #2 |
Re: Mains power cable for philips n2204
As far as I know it was a custom Philips connector. I've only ever seen the socket moulded to a length of mains cable.
It was used on other Philips cassette recorders, and I think, the N1500 video recorder (at least). But the cables are not common. -tony |
9th Jan 2019, 6:53 pm | #3 |
Something makes me think of Eumig film projector power cables...
Don't know what. It could be way off. |
9th Jan 2019, 7:00 pm | #4 |
I posted a scan from an old Maplin catalogue in this thread :
https://www.vintage-radio.net/forum/....php?p=1070760 showing various cassette mains leads including this one. |
9th Jan 2019, 7:05 pm | #5 |
Yes Tony - I remember reading that one - really useful it was too.
Now time machine needed to get back to Maplin as they were in those days please. |
10th Jan 2019, 3:56 pm | #6 |
Re: Mains power cable for Philips N2204
Thanks for the info guys, It doesn't look like I will be able to find one so I'll look into changing the whole thing and maybe go for a PC type connector.
Pete. |
10th Jan 2019, 3:56 pm | #7 |
oh, look at me, I'm a diode
10th Jan 2019, 4:30 pm | #8 |
The chassis plug in the N2204 has a switch that operates when you plug the mains lead in to disconnect the internal battery. So fitting an IEC320 connector could be difficult.
You can run the machine off 9V DC fed in via the 5 pin 240 degree DIN socket on the side (the one with the red dot). Pin 1 is +ve, pin 3 -ve (the pins are numbered 1-2-3-4-5 on this type of DIN connector). Pin 5 is the +ve side of the internal battery, connected to pin 1 by a switch in this socket when no DIN plug is plugged in. One day when I get a round tuit I'm going to make up an adapter with a 5 pin 240 degree DIN plug on one end and a 2.5mm jack socket and coaxial power connector on the other so I can use a normal PSU and remote control (at the same time if I want) with my Philips cassette recorders. |
10th Jan 2019, 4:37 pm | #9 |
I forgot about that little switch.
15th Jan 2019, 6:38 pm | #10 |
I have one spare - just found it. Would it be of use to you?
15th Jan 2019, 9:43 pm | #11 |
Is polarisation important? if not then I believe there are switched versions of the "figure-8" connector.
16th Jan 2019, 11:38 am | #12 |
Hi MACH ONE,
yes, I am very interested in it. How much for it with postage to France ? Pete. |
18th Jan 2019, 8:15 am | #13 |
I will PM you...
