Old 29th Nov 2018, 8:45 pm   #1
GW4FRX
GW4FRX's Avatar
Default BT Caller Display 2000 backlight
I have one of these in the office which is still working well although the backlight failed a while ago. This doesn't really matter but it would be nice to fix it.
Does anyone happen to know what technology the backlight used and whether this particular type of caller display is repairable? There nothing whatsoever about it on the internet, alas.
GW4FRX is offline
Old 29th Nov 2018, 9:23 pm   #2
buggies
buggies's Avatar
Default Re: BT Caller Display 2000 backlight
No idea about the backlight type (although the manual does mention that it may buzz - so probably not LED) but might be worth checking the power adaptor output volts on load in case too low?
George
buggies is offline
Old 30th Nov 2018, 1:38 am   #3
hamid_1
If it makes a high-pitched buzzing noise, it's probably an electroluminescent (EL) backlight. These are usually a blue-green colour. An inverter provides high voltage to the EL panel, making it glow.
EL panels can work for thousands of hours, gradually losing brightness. If the backlight failed suddenly, I suspect the inverter or its power supply has failed. Check the external mains adaptor first: the instruction manual mentions that the backlight will not work on battery power.
You might be able to open up your caller display, find the fault and repair it, but I'm pretty sure that no service information or original parts will be available. These things were not designed to be repaired.
If you are really determined, there are companies that supply electroluminescent panels and the inverters or drivers that make them work, enabling you to repair a faulty EL backlight even when original parts are no longer available. For example https://elpanelandtape.co.uk/el-backlights/
Alternatively you could light the display with LEDs instead. Bear in mind that modifying the caller display unit could void its BT approval.
hamid_1 is offline
Old 3rd Dec 2018, 9:25 pm   #4
GW4FRX
GW4FRX's Avatar
Many thanks for the replies. The adaptor is still working OK as it happens but something's clearly failed inside the device and it looks like a fairly major job to fix it (there's no obvious way to get inside it).
I think on balance I'll let sleeping dogs lie ;-)
GW4FRX is offline
Old 3rd Dec 2018, 11:46 pm   #5
Pellseinydd
I have the same problem with one of my Caller Display 2000's but never got around to looking at it.
They seem to fetch £50+ on eBay - the only one that I know of where you read it across right the room?
Ian
Pellseinydd is offline
Old 4th Dec 2018, 6:51 pm   #6
GW4FRX
GW4FRX's Avatar
Yes indeed, even without the backlight
GW4FRX is offline
