13th Sep 2014, 11:45 pm | #1 |
Power Pentode Output Choke
I have here a couple of pictures of a Telsen Power Pentode Output Choke. 30/15H - 40mA with a 1.3/1 ratio and a 1.7/1 ratio.
Can someone tell me it's purpose within a circuit and where it would be located? Is it an amplifier for the audio output (pentode) valve? It's not an output transformer for matching with a speaker is it? Thanks Nick |
14th Sep 2014, 4:21 pm | #2 |
Re: Power Pentode Output Choke
I'd hazard a guess at it being a load choke for an output valve feeding a hi-z loudspeaker via a capacitor. The strange ratio tap might have something to do with hum cancellation.
14th Sep 2014, 5:23 pm | #3 |
Thanks Chris.
It's definitely an LF Choke but it confuses me because it's almost certainly iron-cored, which would indicate it would be used for valve coupling, or for connecting a loud-speaker to the output valve, but my understanding was that for either of these two functions it should have an inductance of NOT LESS than 50 henries. This choke is much lower. So was it intended for smoothing to cancel hum as you suggest? In which case I was interested to know how and when it would have been employed in a circuit as it looks like it was a late 1920s / very early 1930s component. I don't have sufficient knowledge or experience to tell if it was designed for D.C. current only, or A.C. only, or both. And if it is A.C. then I believe the field of uses could be greater I consider it part of my education and learning to find out. Nick |
14th Sep 2014, 7:58 pm | #4 |
Hi Nick, a consultation of the Telsen "Radiomag" shows it at 10/6 and used with a capacitor to couple to a speaker.
They were also advertised for classB stages as well. They could also be used without a capacitor with certain high Z speakers. Ed |
14th Sep 2014, 8:15 pm | #5 | |
15th Sep 2014, 12:38 am | #6 |
For circuitry of this age, any of FJ Camm's many books are a good guide. There's always at least one set that matches near enough to be of use.
This one just specifies a Pentode output choke, no ratio mentioned. I expect yours has four terminals. |
15th Sep 2014, 2:49 pm | #7 | |
Thanks Bill. I will have a rifle through his books.
Nick |
15th Sep 2014, 7:33 pm | #8 |
Hi Nick, no it was intended to be used with a high Z speaker; used with the OP trans as well it should be OK for a demo.
Ed |
15th Sep 2014, 8:43 pm | #9 |
Think I'm going to have to go away and do some additional reading on speaker matching!
N. |
16th Sep 2014, 9:38 pm | #10 |
Hi Nick, the speaker matching transformer ratio is defined as the square root of the impedance ratio valve required load/ speaker impedance.
Confusion will arise over the various symbols used (ra, Ra, RL). ra is usually the valve anode impedance. The desired load is often taken as 50% of this value for minimum distortion, often written as Ra or RL. Confused yet? In practice, for most low power stages using a 3R speaker any ratio between about 20:1 and 50:1 will produce sound and not damage anything. Your reading will give you all the theory about maximum power transfer and minimising distortion. In general pentode will need a higher ratio transformer than triodes. Cheers, Ed |
16th Sep 2014, 10:33 pm | #11 |
Thanks to each of you for the information and advice. I now understand what a power pentode output choke is, and when and how it is incorporated into a circuit
Typically, this new-found knowledge has now raised additional questions on speaker matching! As it naturally flows from this thread, but is on a different topic, I have started a new thread here (https://www.vintage-radio.net/forum/...d.php?t=109468) Nick |
