Old 19th Jan 2019, 5:49 pm   #1
nmooney
Default Akai 4000DS Mk2 right channel going crazy.
I have bought an Akai 4000DS mk2 that has not been looked after. It has obviously been stored somewhere damp. I did manage to get it working and sounding great playing prerecorded stereo 7.5ips tapes. But the right channel starts to make big crackling noises and the uv meter starts moving back and forth violently. The channel still works inbetween, and it has been intermittent. Any ideas where i should start with this or what could be causing it. If it's going to be a capacitor I'm up for trying to recap it myself. But would be good to know where to start. See this video of the uv meter. This is with no tape playing across the heads.
https://youtu.be/wkSHUuLsUZo
nmooney is offline
Old 20th Jan 2019, 2:52 pm   #2
Michael Maurice
Michael Maurice's Avatar
Default Re: Akai 4000DS Mk2 right channel going crazy.
The problem is usually caused by the now obsolete LD3141 IC. Some people sell replacements.
Forum Moderator
Michael Maurice is offline
Old 21st Jan 2019, 12:01 am   #3
electroanorak
electroanorak's Avatar
I have a few LD3141's. I could part with one FOC of course?
It will be that, I have had this fault before.
I am away until Sunday, so I can post one next week.
Daniel.
electroanorak is offline
Old 21st Jan 2019, 1:40 pm   #4
monaro0162
LD 3141 were only used in the 4000DS MK1, the MK2 switched back to using discreet components.
monaro0162 is offline
Old 21st Jan 2019, 4:02 pm   #5
julie_m
The track select switch on these machines can cause all manner of problems .....
julie_m is offline
Old 21st Jan 2019, 10:39 pm   #6
nmooney
I'll open it up again and have a look. Now that i have had a read about the LD3141 ill have a look and see if they are in there. I had ever read conflicting information on whether they are in the mk2.
I saw a couple off people were replacing them with small circuit boards with the components on them, rather than integrated chip.
I had thought about the track selector switch. When i switch it between sterio and the 1&3 and 2&4 mono tracks the popping and cracking noises still come through. So it had raised my suspicions. Should i get some contact cleaner in there?
nmooney is offline
Old 22nd Jan 2019, 12:57 am   #7
dave walsh
Yes... my machine has these problems with the switch and [so-far] I've kept it going [for transcription purposes only]. But then, I'm not expecting to record or play back on it regularly, as in the 1970's! Luckily the "monkey metal" cam hasn't disintegrated [yet] either. If it does my Tandberg 3300X seems to play back the archived tapes just as well
Wholesale recapping without fore-thought is not recommended on here as it's seen as a form of counter productive guess work. There are [or should be] very many 4000D threads available to read.
Dave W
dave walsh is offline
Old 26th Jan 2019, 10:47 pm   #8
nmooney
Messing with the track selector switch has not improved things. The right channel is almost completely dead now. UV meter only moves a fraction. Opened it up and think i have identified the offending LD3141. Looks like there is a place in the Netherlands selling them.
https://www.electro-andijk.nl/index....category_id=10
nmooney is offline
