Old 20th Nov 2019, 3:54 pm   #1
vampyretim
Default K.B discomatic white noise
Hi all,
I'm trying to reduce the hiss on a K.B discomatic and I read somewhere on this website that the hiss was reduced by replacing the first two OC75's for another type of transistor. Would anyone recommend a suitable replacement?
Has anyone any experience with this type of amp?
Many thanks.
vampyretim is offline
Old 20th Nov 2019, 8:43 pm   #2
crackle
Default Re: K.B discomatic white noise
Here is a list of OC75 equivalent transistors, https://alltransistors.com/crsearch....=0&r2=0&r1r2=0
But have you tried swapping the transistors around, if the noisy one is in TX1 position then move it to TX2.
Mike
crackle is offline
Old 20th Nov 2019, 9:09 pm   #3
Ed_Dinning
Hi Tim, some of the resistors can get noisy, a quick squirt of freezer spray or a blast with a hot airgun can identify the culprits
Ed
Ed_Dinning is online now
Old 9th Dec 2019, 1:56 pm   #4
vampyretim
Thanks guys.
Old 9th Dec 2019, 2:40 pm   #5
paulsherwin
paulsherwin's Avatar
Try whatever you have to hand. You may well find even silicon types will work.
An AC126 should be a perfect sub if you have any.
paulsherwin is online now
Old 8th Jan 2020, 1:27 pm   #6
vampyretim
Hi all,
I've replaced the two front end transistors for silicon types yet am still getting really bad hiss. I also need to replace the 50 ohm lin bias pots but am having real difficulty finding a replacement.
Any help much appreciated.
Old 11th Jan 2020, 9:51 pm   #7
crackle
See Post #30 of this thread, which shows my solution to the trimmer pots.
https://www.vintage-radio.net/forum/...d.php?t=131587
Mike
crackle is offline
Old 24th Jan 2020, 7:09 pm   #8
vampyretim
Hello all,
Just a little update. I'm working on three of these at the moment and they all hiss terribly!
I have managed to bring the hiss down in one of them to very tolerable levels.
I decided after trying several different types of transistors including silicon ones to keep the original oc75's in place, the silicon ones made no difference to the hiss. I then decided out of frustration to replace all of the carbon composite resistors in the preamp for 1/4 W modern types (I think they're carbon film). I still had an annoying hiss until I replaced the negative feedback r21 2.7k resistor.
It now sounds great!
All electrolytic caps have been replaced and I'm quite impressed how punchy these little amps are. I wouldn't advise replacing the oc75's and I'm going to test the other two that I'm working on and see how little I can replace to reduce the hiss.
Thanks for everyones help.
Old 24th Jan 2020, 9:41 pm   #9
PJL
Congratulations, sounds like your persistence has paid off. A good example of why new components are better than old no matter what some say!
PJL is offline
Old 25th Jan 2020, 1:14 pm   #10
paulsherwin
The OC75 is just a low noise OC71. I agree there's no point in changing them if they're not faulty.
Old 6th Feb 2020, 2:24 pm   #11
vampyretim
Hi guys,
I'm having trouble with the mechanics now. The thing seems to be stuck in record playing mode and I can't get it to go along its run to pick up a different record.
Has anyone any experience on the mechanical side?
Many thanks.
Old 7th Feb 2020, 6:10 pm   #12
crackle
I dont consider this item as very suitable for anyone inexperienced to restore, I know this because I have stripped one and restored it to working having not ever seen one before and had to ask for advice on many occasions. But I had restored quite a few record players and other mechanical music players.
There are many mechanical actions that need to take place in sequence in order for it to move along, select a record, load it, position the pickup, play the record, lift the pickup off the record, return it to the rack, and move on to the next selection.
Please can you be more specific as to what the player is doing and how far it is getting in its sequence of events whilst playing and at the end of playing a record.
If you dont have the service manual it is available on my web site. http://www.kbmuseum.org.uk/kb_servic...comatic_kb.pdf
It includes exploded diagrams of the mechanical parts so you can work out how the various trips work.
Have you read through my thread, see link in post #7 of this thread, there may be some clues in there.
It really is getting the mechanism on the bench and getting down close to peer at and see every little action at the end of a record.
Mike
crackle is offline
