Old 4th Oct 2019, 6:12 pm   #1
Pete_kaye
Pete_kaye's Avatar
Default Murphy U472
I have just started looking at this .I will need a pair of 50 UF electrolytics . What/ where should I get them. Is 450v dc adequate 105C ?
Pete_kaye is offline
Old 4th Oct 2019, 6:31 pm   #2
Nuvistor
Nuvistor's Avatar
Default Re: Murphy u472
450 Vdc is fine, These are 500V D.C. but anything over 350vdc would be fine.
https://www.cricklewoodelectronics.c...Capacitor.html
There are other suppliers, check this post .
https://www.vintage-radio.net/forum/...d.php?t=160219
Frank
Nuvistor is offline
Old 5th Oct 2019, 1:19 pm   #3
Pete_kaye
Pete_kaye's Avatar
Default Re: Murphy U472
Can anyone sell me two?
Old 5th Oct 2019, 7:49 pm   #4
Nuvistor
Nuvistor's Avatar
If it’s to replace c63 and c64 the one from cricklewood is a dual 50+50 500 vdc.
Are you looking for two to stuff the original can?
Frank
Nuvistor is offline
Old 7th Oct 2019, 11:03 pm   #5
PJL
Electrolytics of this age are generally pretty reliable although it is best to apply power gently to reform them. Don't think I replaced the one in my U472.
PJL is offline
Old 8th Oct 2019, 5:49 pm   #6
Pete_kaye
Pete_kaye's Avatar
Well ,the red terminal gave 72 UF and 1.8R but the other side gave ' Diode , Vf =...'. There was a loud noise so I switched off. I was on a limiter.
I am planning to restuff.
Old 8th Oct 2019, 6:07 pm   #7
Nuvistor
Nuvistor's Avatar
I don’t have any but Cricklewood have these, probably CPC, RS and Farnell have similar ones.
https://www.cricklewoodelectronics.com/47H450.html
Was the loud noise from the smoothing can? They can explode and when they do they usually spay silver foil over the chassis, you don’t want to be too near if the fail.
Frank
Nuvistor is offline
Old 8th Oct 2019, 6:11 pm   #8
Pete_kaye
Pete_kaye's Avatar
I forgot to say that there was a hole leaking stuff near one terminal!
Old 22nd Oct 2019, 2:30 pm   #9
Pete_kaye
Pete_kaye's Avatar
I got some 50 uF caps very cheaply via China and they just arrived . I have fitted this new part across the rectifier to replace an old waxy but is it adequate as the Murphy notes say '1000 Vdc' ?
Old 22nd Oct 2019, 7:45 pm   #10
westcliff
westcliff's Avatar
That one's okay as it is an X2 type and marked for 250V AC.
Gus.
westcliff is offline
Old 25th Oct 2019, 1:09 pm   #11
Pete_kaye
Pete_kaye's Avatar
Thanks .It is now working well on Mw and LW with 2 new caps . However, there is just a high pitched squeal on VHF , with or without aerial. There is a hint of station at several points. The UCC85 valve is tested. Where to now?
Old 3rd Nov 2019, 12:25 pm   #12
Pete_kaye
Pete_kaye's Avatar
Sorted . As advised , I changed C23 and VHF came on . Subbing a better UCC85 gave all stations across the band; the previous one did not. It is now back in the case and working well- thanks to this site.
