Old 29th Aug 2019, 9:54 pm   #1
Uncle Bulgaria
Uncle Bulgaria's Avatar
Default Grey insulating cardboard
Ahoy,
In my Uhers there are rather fine pieces of thin, stiff, grey cardboard used between circuit boards and covers. Perhaps they aren't anything special, but they have nice pressed, smooth, shiny surfaces.
If I wanted to use anything similiar in my own projects, or replace something in an old piece of equipment, does anyone know the name of this cardboard equivalent, or if it's something one can still buy today? Does it have ratings or did they just use bits of cereal packet?
Uncle Bulgaria is offline
Old 29th Aug 2019, 10:12 pm   #2
MotorBikeLes
Default Re: Grey insulating cardboard
I dismantled so old battery drill batteries for cell renewal. They had similar card under and around the cells. I replaced it with card cut from a "hanger" out of a filing cabinet. The sort which slide in and out with the files sitting in the "cradle".
try that.
Les.
MotorBikeLes is offline
Old 29th Aug 2019, 10:30 pm   #3
ajgriff
ajgriff's Avatar
Is this a corrugated plastic material? If so, the brand name is Correx and sheets are widely available in different sizes. Probably something different.
Alan
ajgriff is offline
Old 29th Aug 2019, 11:07 pm   #4
Argus25
No Longer a Member
This is the card I always use for those applications & more:
https://www.jaycar.com.au/pressboard...erial/p/HG9985
It is around 1mm thick and for cardboard it has an amazing dielectric strength. It also looks very good varnished.Have a look at the battery case made out of it on page 12-13 of this article:
http://worldphaco.com/uploads/USING_...CILLOSCOPE.pdf
PS: the original card Jaycar supplied was a redish color, like that in the article, of late it has changed to a pale brownish color but it is electrically identical.
Argus25 is offline
Old 29th Aug 2019, 11:49 pm   #5
kevinaston1
The thin grey cardboard is called FISH PAPER.
It is used on a lot of stereo high power amplifiers, where the two amplifier channel boards have to be insulated from the metal cabinet.
If you have a local Pro Audio power amp repair company, they may well have some.
I had 20 sheets in stock in my department, before I was made redundant. I doubt it is still there, the new management who took over sent many thousands of pounds worth of parts to the tip.
Kevin
kevinaston1 is offline
Old 30th Aug 2019, 1:03 am   #6
Herald1360
Herald1360's Avatar
Sounds like what I knew as "Elephantide"- a stiff grey-blue card like sheet material.
Try this: RS Stock No. 775-7790
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 30th Aug 2019, 1:16 am   #7
Terry_VK5TM
Terry_VK5TM's Avatar
Yes, "Elephantide"
The use of ordinary cardboard is fraught with danger.
In damp/humid climes, it can absorb moisture and not only become conductive but it also promotes corrosion when in contact with metallic surfaces.
If you really, absolutely, must use cardboard, soak it in varnish or shellac and let it dry thoroughly before use.
Terry VK5TM
https://www.vk5tm.com/
Terry_VK5TM is offline
Old 30th Aug 2019, 7:41 am   #8
Uncle Bulgaria
Once again, the hive mind comes up trumps! Looking at listings for 'fish paper' and the RS link, I think we've found it.
As so often with the Infobahn the crucial thing is discovering the right search terms. I'll get some of this and compare it what I have. It's certainly more like cardboard than plasticard.
Thanks all - don't worry Terry_VK5TM, I don't think I'll be desperate to put any projects in cardboard boxes! Shellac, however, is a lovely material with many uses...
Old 30th Aug 2019, 8:03 am   #9
Radio Wrangler
Radio Wrangler's Avatar
Transformer winding firms are likely to stock fish paper in some of the thinner grades.
I've always wondered just what fish have to do with it.
Radio Wrangler is offline
Old 30th Aug 2019, 9:48 am   #10
Terry_VK5TM
And just so you can be spoilt for choice:
RS 775-7794 PET, Press Paper Elephantide Laminated Presspaper
Terry VK5TM
Old 30th Aug 2019, 10:28 am   #11
ajgriff
ajgriff's Avatar
Wasn't there some story about it originally being used to wrap wet fish? Probably an old fishmonger's tale!
Alan
ajgriff is offline
Old 1st Sep 2019, 7:33 am   #12
FrankB
Fish paper comes in various colors and thicknesses.
When I need any, I go to my local electrical wholesale shop and they sell me some.
Other sources might be motor rewinders & transformer mfgr's.
FrankB is offline
Old 1st Sep 2019, 8:14 am   #13
stitch1
stitch1's Avatar
Originally Posted by Terry_VK5TM View Post
Yes, "Elephantide"
Elephantide or Presspahn is still available. I restored a VHF81 and the service sheet said ‘slide the Presspahn heat deflector out’ but it was missing, I was pleasantly surprised to find they were still going and I ordered direct from them.
https://secure.presspahn.com/Cart/in...2g8li0aihgugg0
John
stitch1 is offline
Old 1st Sep 2019, 11:40 am   #14
Boulevardier
When I was looking for some on the web, it seemed much more readily available in the US than in Europe or UK. Can't think why...
Boulevardier is offline
Old 2nd Sep 2019, 12:45 pm   #15
Uncle Bulgaria
Thanks for the tip, stitch1. Unfortunately Presspahn only sell brown (I happen to like the blue!) so it wouldn't match the Uhers, but the site looks an excellent source for all those materials I'm never quite sure where to get.
ajgriff - I hope they just used newspaper as this stuff seems rather too heavy-duty for real fish! Unless they needed the insulation for the stingray tails...
FrankB - this is where the US has some advantages over the UK. Here it's very rare to find such a shop, and they'll only sell lowest common denominator parts anyway. A real nadir was when I couldn't find anywhere in Brighton to buy good quality mains flex, an in-line switch and a good plug. I was reduced to Homebase with plastic packets of cheap and nasty pieces sold at outrageous prices.
Old 2nd Sep 2019, 2:01 pm   #16
ajgriff
ajgriff's Avatar
I'd guess that old fish wives would have sourced extra thin paper from the US.
Alan
ajgriff is offline
Old 8th Nov 2019, 11:01 pm   #17
Uncle Bulgaria
I got some of the RS Elephantide. It looks the part except one side has a very shiny plastic film on. I'm not sure if I'm supposed to leave this on or take it off - it doesn't peel off easily, and leaves a torn surface behind so it's not an adhesive protector.
The datasheet says '100% cotton' so is this some part of the process? The stuff already in the Uher is matt both sides, so I don't know if one side or the other is supposed to be 'hot'.
As it's just a shield so the broken main board doesn't touch the bottom cover it won't matter, but it might if I'm supposed to use it the right way round in a valve situation!
Old 9th Nov 2019, 12:48 am   #18
Terry_VK5TM
Even the manufacturers don't specify which side is "up", so I guess it doesn't matter.
Terry VK5TM
Old 9th Nov 2019, 12:58 am   #19
joebog1
Dad ( master rewinder and design engineer) always said shiny side to hi volts. I didnt ask, and he never said why.
Joe
joebog1 is offline
Old 9th Nov 2019, 5:39 pm   #20
Uncle Bulgaria
Thanks both. It looks like for this application, aesthetics wins out and it's shiny side down to match the rest.
Why I mind I don't know - who else is going to look inside the bottom of an old cassette desk and notice it?
Perhaps it's like Gaudi and the Sagrada Familia in Barcelona - on being asked by a bishop why he'd designed golden angels right up on the top of the spires where no-one could see them, he replied 'God will see them'.
