26th Jul 2016, 9:39 pm | #1 |
Toshiba RT-7025 'boom box' (1985)
A neighbour offered me this set in a pretty dusty condition. 1980s boom boxes are not my thing at all, but as usual I couldn't see it skipped so I took pity on it. The 4-band AM/FM radio basically worked, but the cassette mechanism didn't, due to the main drive belt having turned to goo.
The machine itself is a delight to work on, and appears to have been designed with quick and easy servicing in mind; the speakers are detached by sliding up, five screws release the front panel, and the graphic equaliser board and cassette mechanism simply lift out, the wires being long enough to enable the cassette deck to be turned over for access to the belt. The motor is released by twisting it, enabling the goo to be cleaned off the pulley with liquid lighter fuel. Two screws release the rear capstan bearing, and a new belt can be slipped on in seconds. I brushed away the accumulated dust, gave the heads a good clean and reassembled everything. Off it went like a good 'un, giving remarkably good quality sound on record and playback, especially when recording from the built-in microphone. A quick wipe over with Baby Wipes and a duster restored a reasonable finish to the cabinet. The repair job took barely any longer than writing this report! Phil
26th Jul 2016, 9:47 pm | #2 |
Re: Toshiba TR-7025 'boom box' (1985)
There were a number of very similar models by a range of manufacturers made at that time. I owned a Philips one for a while. The detachable speakers are nothing special but do allow it to be used semi-permanently in a bedroom or kitchen with a decent stereo spread.
They do tend to look a lot more sophisticated than they actually are - I used to call this the "sheep in wolf's clothing" look. Nevertheless, they work well enough for what they are. |
26th Jul 2016, 10:07 pm | #3 |
You've summed it up very well, Paul. The cassette deck is sturdy, but a bit clunky and lacks any sophisticated features such as auto-stop, Dolby or a tape counter. The radio works pretty well though, even on short wave.
