11th Nov 2019, 11:59 pm | #1 |
Sony HP-511. Belt size needed.
hi
i have a sony hp-511a on the bench. the drive belt is in bits, the service manual gives no indication of the size. anyone have the dimensions please. ? |
12th Nov 2019, 12:28 am | #2 |
Re: belt size needed
I suspect you'll have to do some measuring. Cotton tied around the pulleys has worked for me in the past. There was a thread recently about measuring belts but I can't immediately locate it.
Alan |
12th Nov 2019, 12:41 am | #3 |
12th Nov 2019, 5:20 am | #4 |
Problem solved. Well done!
Alan |
14th Nov 2019, 11:18 pm | #5 |
Re: Sony HP-511. Belt size needed.
thanks to all for the help. managed to find the correct size dimensions for the belt for the sony hp-511a. for the record its 195mm x 6mm. the 6mm is important otherwise the speed change won't operate correctly.
