Reply
Old 10th Jun 2023, 4:55 pm   #41
steve1010uk
Default Re: Ferguson 1500 series Television
Also good advice from Paula, it's worth having a good look at the wiring of the line scan coils, it could just be something simple like a corroded or broken connection to one side of the line coils
steve1010uk is offline   Reply With Quote
Old 11th Jun 2023, 6:56 pm   #42
Silvered_Mica
Silvered_Mica's Avatar
I wouldn't suspect the scan coils yet, check C92 it might be momentarily dragging down the boost rail. Also check the correction cap C90, it probably won't cause the symptoms you have but I think it's a Hunts moldseal type if memory serves.
Trust Me, It's a Magic Iron (∩ ͡° ͜ʖ ͡°)⊃━☆゚. * ・ 。゚, 📻📺🦔📡
Silvered_Mica is offline   Reply With Quote
Old 11th Jun 2023, 9:13 pm   #43
Red to black
Red to black's Avatar
With a keystone raster like that it will always be a scan coil fault
Red to black is offline   Reply With Quote
Old 12th Jun 2023, 9:21 am   #44
Welsh Anorak
Welsh Anorak's Avatar
Agreed. I'd remove the yoke and have a close look at the coil terminations - you may see a green bit of corrosion, especially if the set's been in damp conditions.
Luckily any contemporary scan coil assembly will do, but best if you can find a 1500 one - shouldn't be too difficult.
Glyn
www.gdelectronics.wales
Welsh Anorak is online now   Reply With Quote
Old 12th Jun 2023, 10:28 am   #45
Hybrid tellies
Hybrid tellies's Avatar
If the scan coils are ok it may be the linearity sleeve.
If these are ok check the voltages around the line output stage and line oscillator valve.
I have had a few faults like this in the past where by checking voltages around the line oscillator valve has cleared or partially cleared the fault whilst I touched one of the valve base pins with the meter probe helping to localise a fault to a capacitor or resistor.
Simon
BVWS member
Hybrid tellies is offline   Reply With Quote
Old 31st Jul 2023, 6:51 pm   #46
thermionic
thermionic's Avatar
Hi everyone.
I offered to repair this set for Newgirl2013 after she had posted a request for a TV repairer in Cornwall in the Services Wanted section.
I collected the set on Friday, and had a chance to put it on the bench today to see what could be done.
First impressions revealed a 20” 1500 chassis in a Ferguson coat, with a 4 button mechanical tuner. The tuner buttons were sluggish and not latching. A round white mains cable is fitted which is not original, - this would have been a flat twin cable with a grey or black sheath originally.
The back cover was removed after removing the 5 original screws & washers from the back. That’s a good sign! This revealed a PCB with a green solder resist suggesting that this is a late model.
The CRT installed is a ‘SOLUS’ brand, which I understood was a replacement market brand rather than one that would be supplied direct to a manufacturer, but the valves fitted are a mix of SOLUS, T.C.E and Mazda, so maybe its original.
Examining the soldering on the main PCB, it appears to have had no work done on it, - even the solder on the dropper tags looks original!
That’s it for now, next is power up to confirm the fault condition as described by Sharon, above.
Cheers. SimonT.
ID:	282450   Click image for larger version
ID:	282451   Click image for larger version
ID:	282452   Click image for larger version
The honesty of imperfection..........
thermionic is offline   Reply With Quote
Old 1st Aug 2023, 1:34 pm   #47
Newgirl2013
Newgirl2013's Avatar
Hi Simon
The mains lead came as a surprise
I would never thought it would be a three core
When I used to see the 1500s the mains leads were always twin grey mains leads
Hope you can sort the tv
Many thanks
Sharon
Newgirl2013 is online now   Reply With Quote
Old 2nd Aug 2023, 7:16 pm   #48
thermionic
thermionic's Avatar
Last night It was back to the set, and power up time!
Up came the strange raster that Sharon (Newgirl2013) had witnessed. There was a louder than normal background hum from the speaker, and the main HT line (HT1) was much lower than it should be.
Out with the multi section electrolytic then - and what a mess was discovered! All 3 sections of this can were practically high value resistances, and only a mere suggestion of any capacity.
A rummage through my box of multi section electrolytics did not yield an exact replacement, ( 150uF + 150uF + 100uF ), but I did find a can that I hoped would, at least, get the chassis up & running whilst I try and source an exact replacement.
My substitute can ( 100uF + 68uF + 220uF )was carefully adapted to fit the PCB footprint, whilst being careful not damage the PCB. I was rewarded with an almost normal raster, which, thankfully, has lifted any suspicion from the scan coils…. Yay!!
ID:	282597   Click image for larger version
ID:	282598   Click image for larger version
Old 2nd Aug 2023, 7:22 pm   #49
thermionic
thermionic's Avatar
………Incidentally, The date codes on the electrolytic and this valve seem to date this set from very late 1977, so it really must be near the final run of these great chassis!
So, the next job is to repair the push button mechanism on the tuner, so that a signal can be tuned in to evaluate what needs attention next.
( The frame timebase is an obvious patient)!
Cheers.
SimonT.
Old 3rd Aug 2023, 9:26 am   #50
Welsh Anorak
Well, you live and learn!
The green chassis lacquer does point to the very last production run. You seem to have a pretty decent CRT as well which will only get better with time.
We used to look after well over a hundred of these TVs for a local holiday camp until it was deemed that the happy campers deserved colour. Radio Rentals offered an excellent deal to the owners, so soon the camp was full of TX9s and the skips were full of the poor 1500s.
Glyn
Old 4th Aug 2023, 6:10 pm   #51
Colourstar
Colourstar's Avatar
You know I could be wrong but I wonder if that set has had a later chassis put in. I'm sure when I had one of those some years ago it had the red pcb. I don't have the relevant Ferguson brochure to hand but I'd put that cabinet design with the basic mechanical tuner to about 1973. I think by the time of the very late 1500s in 1977 they were using varicap tuners.
I'll have a rummage through my Ferguson brochures to see if I can prove (or disprove) my theory!
Steve
Colourstar is offline   Reply With Quote
Old 4th Aug 2023, 7:04 pm   #52
thermionic
thermionic's Avatar
Steve
That would be interesting, Steve. A replacement chassis is a possibility.
The model number on the back cover is 3821, if that helps you in your quest!
Cheers……SimonT.
Old 4th Aug 2023, 7:20 pm   #53
thermionic
thermionic's Avatar
Today, I’ve repaired the tuner.
It was suffering from the usual Thorn mechanical tuner problem! The plastic spring retainers on each of the selector shafts had disintegrated, the remains rattling around the bottom of the sets cabinet.
The usual remedy for this is to fit appropriately sized steel washers onto each of the 4 shafts, and this is exactly what I did.
The surface rust was removed with fine grade sandpaper and GT85 spray. Finally, the shafts and square section rear actuator bars had a very small smear of petroleum jelly applied.
The other failure mode on these particular tuners is that the tuner unit actuating bar can become detached from the pivot ends. The bar, which is attached by solder onto the pivot ends usually becomes loose due to the solder fracturing. On this particular tuner, the soldering appears original, and is still in good condition with no signs of distress.
Tomorrow, we’ll have a picture!
Cheers……. SimonT.
ID:	282718   Click image for larger version
ID:	282719   Click image for larger version
ID:	282720   Click image for larger version
Old 4th Aug 2023, 7:28 pm   #54
thermionic
thermionic's Avatar
The green chassis lacquer does point to the very last production run. You seem to have a pretty decent CRT as well which will only get better with time…….
Thanks Glyn.
Yes, the CRT looks promising, I must admit that I was surprised to see one branded SOLUS, I’m not sure who would have originally manufactured these, a European manufacturer maybe?
At least it’s not one of those Unitra tubes with the phosphor that looks like the surface of the moon!!!
SimonT.
Old 4th Aug 2023, 10:15 pm   #55
Bobdger
Most of the 6823s that I had new in 1976 had green colour pcbs. I used hi melting point solder for the tuner bars. Inside the tuner are 4 silver springs that earth the bar with the movable tuning gangs. I use to remove them, the solder was always cracked and clean with carbon tet. Bob.
Bob, BVWS member
Bobdger is offline   Reply With Quote
Old 5th Aug 2023, 10:04 am   #56
HamishBoxer
HamishBoxer's Avatar
Solus tubes were pretty good, as were there valves, not sure if made in UK or not.
Get your Weller gun out for that tuner bar.
HamishBoxer is offline   Reply With Quote
Old 5th Aug 2023, 3:11 pm   #57
Newgirl2013
Hi Simon
Are you going to replace the chassis?
Sharon
Old 5th Aug 2023, 4:10 pm   #58
Hybrid tellies
During my spell at Radio Rentals, and if memory serves me correctly we used Thorn New Life tubes for colour and Solus Tubes for black and white.
That Green chassis along with the use of a mechanical tuner indicates to me that this is an earlier version 1500. By 1977 they were using electronic varicap tuning and the more common red PCB. Maybe the smoothing can was a replacement fitted in 1977.
One final point the early 1500, like the 1400, may need the width chain resistors checking/changing as they could burn up and catch fire.
Simon
BVWS member
Old 5th Aug 2023, 7:17 pm   #59
thermionic
thermionic's Avatar
Today the tuner was refitted, and the set powered up. No great surprises....... a picture was soon tuned in!
My only issues were an intermittent frame height variation, which was due to R123. ( 330K), and Width variations due to R131 (1M8).
The ubiquitous R44 ( 47K) was factory fitted with a 1 Watt resistor. Its value was checked anyway, and was fine. As this set is being returned to a forum member, then I replaced a few capacitors as a precaution. These were, - C84 - mains filter capacitor. C77 - heater bypass capacitor, - C82 Boost Rail de coupler and C98, - PL504 Screen grid de coupler. The capacitors in these positions were of a type that I don’t have faith in.....simple as that!
The remaining electrolytics are mostly Rubycon and are in good condition.
This chassis is definitely late 1977 so I guess it’s possible that this has been fitted into an earlier cabinet with the mechanical tuner and replacement CRT?
The set will be soak tested now to see if any other issues present themselves. I’ve been offered a replacement main electrolytic, so will wait now for this to arrive.
Cheers. SimonT.
ID:	282816   Click image for larger version
ID:	282817   Click image for larger version
ID:	282818   Click image for larger version
Old 5th Aug 2023, 7:19 pm   #60
thermionic
thermionic's Avatar
Originally Posted by Newgirl2013 View Post
Hi Simon
Sharon
Hi Sharon. No, we were wondering if this chassis is newer than the cabinet! So, it may have been swapped over at some point in its history.
SimonT.
Reply
