Old 22nd Nov 2017, 10:20 pm   #61
ms660
ms660's Avatar
Default Re: Dansette Challenge 100 Switches
Originally Posted by Hoddbod View Post
Here are photos of originalhttps://www.vintage-radio.net/forum/attachment.php?attachmentid=152729&stc=1&d=1511382 567 switch.
Lower left tag = Mains live in, upper left tag = Mains live out.
Lower right tag = Mains neutral in, upper right tag = Mains neutral out.
Lawrence.
ms660 is offline
Old 22nd Nov 2017, 10:24 pm   #62
Station X
Station X's Avatar
That's the original switch Lawrence. All we need now is a picture of the new one.
Graham. Forum Moderator
Station X is online now
Old 22nd Nov 2017, 10:29 pm   #63
ms660
ms660's Avatar
Yes I know that, I've been waiting for yonks like everyone else for a decent photo of the new one, what's more with the original one it looks like an attempt at gaining entry has been tried just like it was on the replacement one.
Lawrence.
ms660 is offline
Old 23rd Nov 2017, 11:30 am   #64
Hoddbod
Here are photos of the new switch and old switch.Both are u/s. I hope these will be of use.
The back of the switch with 4 tags is marked F D and C A. The three other tags are numbered 1 and 3 the middle tag is not numbered I presume it is 2. Is this the wiper tag?
Hoddbod
ID:	152746   Click image for larger version
ID:	152747   Click image for larger version
ID:	152748   Click image for larger version
Last edited by Station X; 23rd Nov 2017 at 11:44 am. Reason: Post moved here from another thread.
Hoddbod is offline
Old 23rd Nov 2017, 12:20 pm   #65
Station X
Station X's Avatar
Set your meter to ohms range. Touch the probes or croc clips together and check that the reading changes from infinite to near zero.
Turn the switch ON.
Connect the meter between C and F. With any luck you'll see a low resistance.
Connect the meter between A and D. With any luck you'll see a low resistance.
Turn the switch OFF.
Connect the meter between C and F. With any luck you'll see infinite resistance.
Connect the meter between A and D. With any luck you'll see infinite resistance.
IF these tests are successful:-
Connect the incoming mains to tags A and C.
Connect the wires going to the turntable and transformer to tags B and F.
IF the test results are different, report back what you find.
Old 23rd Nov 2017, 12:54 pm   #66
Hoddbod
Thank you for that. But what about the Earth [Green] from mains where does that go? On the old switch it was soldered to the switch metal casing with a wire jump from ground tag. This new switch is no good now. I will have to buy another and try again.
Hoddbod.
Hoddbod is offline
Old 23rd Nov 2017, 1:06 pm   #67
Station X
Station X's Avatar
Why do you think the switch is faulty? What test results did you get?
It's not unusual for a pot to have one end of the track grounded to the case. It's a screening measure. I'd have thought a better place to connect mains earth to would be the player's chassis. If it was originally connected to the pot's case though, that's where you should connect it.
Old 23rd Nov 2017, 1:40 pm   #68
Hoddbod
Hi.
What about the blue cables one goes to the valve and the other goes to where the stylus wires are attached under the turntable. The last picture is of the transformer with black and brown cables going to motor.These are attached to two red cables witch go to the switch.
Hoddbod.
ID:	152754   Click image for larger version
ID:	152755   Click image for larger version
Last edited by Station X; 23rd Nov 2017 at 2:08 pm. Reason: Post moved here from another thread.
Hoddbod is offline
Old 23rd Nov 2017, 2:04 pm   #69
Station X
Station X's Avatar
The blue screened wires carry the signal from the cartridge to the volume control and from the volume control to the amplifier.
Connect them just as they were connected to the original pot.
You still haven't reported the test results for the switch.
GET RID OF THOSE LOOSE STRANDS OF WIRE FROM THE RED WIRE AT THE TRANSFORMER BEFORE THEY CAUSE A SHORT
Old 23rd Nov 2017, 3:00 pm   #70
Hoddbod
The switch is no good it did not work after the fuses blew. I will buy another and try again. But i'm not very hopeful of it working. Does it matter what tags the red wires use These are the two wires attached to the black and brown wires going to the motor. And will the ground wire from blue cable lead need a wire bridge like the old switch?
Hoddbod.
Hoddbod is offline
Old 23rd Nov 2017, 3:09 pm   #71
Station X
Station X's Avatar
The switch is no good it did not work after the fuses blew. I will buy another and try again. But I'm not very hopeful of it working.
If the fuses blew it was most likely because the switch had been wired in incorrectly. It does not necessarily mean that the switch has been damaged. Why not test it as described earlier? You'll need to do that with any new switch in any case to identify the correct tags.
It matters in as much as you'll need to connect them to the correct pair of tags once you've identified them, but you can connect them either way round.
Yes. It's a screening measure.
Hoddbod.
Old 23rd Nov 2017, 3:30 pm   #72
Hoddbod
Hi. I E Mailed Bowoods asking advice on wiring. They sent me a reply. A&C are isolated from D&F. If you bring live into terminal A you take live out of terminal C. If you bring neutral into terminal D you take neutral out of terminal F.
Is this info. any use to you?
Regards.
Hoddbod
Hoddbod is offline
Old 23rd Nov 2017, 3:47 pm   #73
Station X
Station X's Avatar
It tells me that my assumptions in post #66 were wrong.
Connect live of the mains cable to A.
Connect neutral of mains cable to D.
Connect one red wire to C.
Connect the other red wire to F.
Have you tested the replacement switch bearing this in mind?
Old 23rd Nov 2017, 4:22 pm   #74
Station X
Station X's Avatar
I made my (incorrect) assumptions, as to which tag was which, based on the fact that I was expecting a symmetrical layout.
ie A paired with D and C paired with F.
Old 23rd Nov 2017, 4:31 pm   #75
ms660
ms660's Avatar
A(B)C
D(E)F
Lawrence.
ms660 is offline
Old 23rd Nov 2017, 4:38 pm   #76
Station X
Station X's Avatar
Originally Posted by ms660 View Post
A(B)C
D(E)F
Lawrence.
Yes I get it, but I was thinking more of the layout of the rivets.
Old 24th Nov 2017, 9:50 am   #77
Station X
Station X's Avatar
Several off topic posts deleted.
Old 24th Nov 2017, 10:05 pm   #78
Hoddbod
Hi. iv'e managed to repair the old Pot.[I hope]. i get infinitive when switched off. And 1.5 Ohms when switched on.Is this OK.?
Thank you for all your advice
Hoddbod.
Hoddbod is offline
Old 24th Nov 2017, 11:38 pm   #79
Station X
Station X's Avatar
By old switch I assume you mean that originally fitted?
Is that measurement across both sets of tags? ie The two left tags and the two right tags (four measurements in all).
If so the switch is OK.
Old 26th Nov 2017, 4:21 pm   #80
Hoddbod
Hi. Success I did not use original. Bought another from Bowood's wired as instructed and now it works. All i need now is switch knobs because the old ones just broke. I will make some out of wood because new ones are expensive. All the best for all the advice over the switch saga.I was despairing that i would ever succeed.
All the best.
Hoddbod.
Hoddbod is offline
