14th Feb 2006, 9:15 am | #1 | |
"Civic" Brand
Somebody has asked me about a "Civic" brand name ...
TTFN, Jon |
14th Feb 2006, 9:22 am | #2 |
Re: "Civic" Brand
I think that Civic was a Currys brand name.
14th Feb 2006, 9:30 am | #3 |
Re: "Civic" Brand
I'm not sure about the Civic side of things, but the deck sounds like a Motek unit - these were used on a few budget models as an alternative to the BSR ones. These decks were not the last word in engineering...but did the job and at least offered a good fast winding time!
Rather like the BSR TD2 they came with their own Motek heads already fitted to the deck. In my opinion these were the biggest weak point - at 7 1/2ips they just about matched what other machines offered at 3 3/4ips. Stewart |
14th Feb 2006, 9:46 am | #4 |
Re: "Civic" Brand
Re. your Civic, the deck could be the Motek (5 push buttons to right of head block & speed change on left of deck )or the Collaro studio(5 large buttons in centre of deck below head block), spd/ change to right of push buttons.
Doffery |
14th Feb 2006, 9:52 am | #5 |
Re: "Civic" Brand
Hello,
The CIVIC brand name was part of a large electrical group that included BROADMEADS, J & M STONE, J & F STONE, GREYS and others. They were the popular High Street stores before DIXONS took over this role. They were sold in 1973 to the GKN group purely for their finance company side. Their customers tended to buy on H.P. and the credit side must have been massive. The CO-OP brand name was DEFIENT and the CURRYS brand name, WESTMINSTER. DIXONS who later took over CURRYS used MATSUI among others. Regards. JOHN. |
14th Feb 2006, 1:17 pm | #6 |
Re: "Civic" Brand
Thanks for the replies. Attached is a pic of the unit.
TTFN, Jon |
14th Feb 2006, 1:27 pm | #7 |
Re: "Civic" Brand
I have and have seen a radio with the brand name 'Civic' too. It was a foreign looking set designed for the British Market. Similar to Unitra.
Are there two brands with the same name? Cheers, Steve
14th Feb 2006, 1:33 pm | #8 | |
Re: "Civic" Brand
Paul |
14th Feb 2006, 1:34 pm | #9 |
Re: "Civic" Brand
Hi Gents, The Elizabethan LZ29 was a direct equivalent. I think the circuit was in Malloy & Poole. If not I mat have a copy.
Ed |
14th Feb 2006, 4:47 pm | #10 | |
Re: "Civic" Brand
The machine looks very similar to the Elizabethan LZ29, I seem to recall that the LZ29 had phono sockets for inputs/outputs and a slightly different control panel. Without the information already posted I would have said that this machine looks like a "cross breed" between the Elizabthan LZ29 and a Fidelity Argyll of some description. Andrew |
14th Feb 2006, 10:08 pm | #11 |
Re: "Civic" Brand
Hello,
Here is some more info on the provenance of the "Civic" brand: J & M Stone Ltd, in 1955, a TV and radio retailer with multiple outlets (in 1950, they had 64 shops and Max Stone was the MD – the “J” was John Stone). In the same year, they acquired Civic Radio Services Ltd, of Birmingham (with 17 branches). Circa 1960, all branches were converted to trade as “Civic”. They either went into receivership or were taken over in the late 60’s/early 70’s..... The Firth Cleveland Group, in 1960, acquired 53% of Solartron Electronic Group Ltd, Simmonds Aerocessories and control of Broadmead Ltd (owner of >500 radio stores, including Max Stone, Civic Radio Services and Escott Brothers). By 1968, it also owned SNS Communications Ltd, of Bournemouth. Firth Cleveland was a steel/engineering company that became a mini-conglomerate. GKN (formerly Guest, Keen & Nettlefolds Ltd) acquired Firth Cleveland group in 1972. I seem to recall Harry Worth (remember him?) advertising Civic on TV - many years ago! Regards, Dazzlevision |
15th Feb 2006, 9:14 am | #12 | |
Re: "Civic" Brand
Mike. |
15th Feb 2006, 11:06 am | #13 |
Re: "Civic" Brand
It does look indeed like a Collaro deck, although the control panel is reminiscent of Elizabethan and Fidelity models. Elizabethan did make models which used both the BSR TD2 deck for single speed versions and the Collaro deck for three speed versions, so it does look if the mystery player is based on an Elizabethan.
15th Feb 2006, 7:33 pm | #14 |
Re: "Civic" Brand
As from the "tape Recorders" book of 1970 tells me, this is a Magnavox Studio deck, they also go on to say that the pillar right to the head is not a tape guide, this is a three motor deck with adjustable turntables, the hubs can be moved up or down by adjusting the screw in the centre of the cine spindle, under the front plastics to the right f the pinch roller there is a loose screw which should not be tightened as its a flywheel lock.
15th Feb 2006, 9:27 pm | #15 |
Re: "Civic" Brand
Hi Gents, the latest description sounds like the one I had many years ago. This was the LZ29, but it had the Collaro Deck as I have the instructions for it.
Were Magnavox and Collaro related? Ed |
15th Feb 2006, 11:52 pm | #16 |
Re: "Civic" Brand
I'm surprised that there isnt a label on this M/c somewhere, Sometimes they put a label underneath.. The Deck on the machine in the pic is a Collaro Studio deck, It was used by a lot of firms making the cheaper range of recorders. Quite a good deck for the money and better than the BSR deck .. I think Magnavox where connected in some way but not sure if same firm. The older 3 speed reversible deck seemed to vanish when the Collaro studio came along.. The latter could be bought or supplied with 4 track heads if I remember.. Peter {Reelguy}
16th Feb 2006, 2:17 pm | #17 | |
Re: "Civic" Brand
They were also very quiet in operation unlike some of "other" manufacturers decks of the time. Andrew |
16th Feb 2006, 2:23 pm | #18 | |
Re: "Civic" Brand
http://www.time.com/time/archive/pre...826099,00.html Seems like Magnavox bought Collaro in 1960. |
16th Feb 2006, 2:33 pm | #19 | |
Re: "Civic" Brand
Just thought I'd pass this on :-
Jon |
16th Feb 2006, 6:45 pm | #20 | |
Re: "Civic" Brand
A Mr CG Barker used to work there, until he founded Magnecord: http://history.acusd.edu/gen/recording/magnecord.html Nick |
