19th Feb 2018, 9:30 pm | #1 |
Revox B77 mk2 hum?
I've decided to use r2r and purchased a Revox B77 mk2.
Works flawlessly apart from hum when you get within 3 feet. I've no idea if it is meant to be silent or if a low hum is expected presumably from the transformer? I can barely hear it in a silent room from 3 feet away and nothing when music starts. Also I assume a half track 3.75 and 7.5 model can only play the tape in one direction? I'm assuming only quarter track models can do that. Thanks.... |
19th Feb 2018, 9:46 pm | #2 |
Re: Revox B77 mk2 hum?
There should be no hum from the machine but what you will get is a slight high pitch whine which is characteristic of these machines,.
Half track in stereo only plays in one direction, quarter track plays in stereo in both directions. |
19th Feb 2018, 10:13 pm | #3 |
Definitely hum. Yes I noticed the high pitched wirling
19th Feb 2018, 10:16 pm | #4 |
Oops dog pushed me and I sent above message early! Any ideas what the hum is apart from transformer noise? Or is that like asking a mechanic what that engine rattle is over the phone?
19th Feb 2018, 10:27 pm | #5 |
I've just switched on again and when placing my ear directly over one of the top vents it's actually more of a low whirring noise which makes that high pitched sign off when turning off so it's probably motor noise? Stabbing in the dark...
20th Feb 2018, 11:26 pm | #6 |
When you switch on the pitch of the noise should take a second or so to rise to its normal pitch. It should also change when you change speed.
