Old 18th Sep 2021, 10:26 am   #1
Christoffrad
Default PE06/40N - AVO valve tester settings
I have what I believe to be a valve type PE06/40N
The AVO valve tester settings are given for a PE06/40P as
123 114 500 but the valve tester then reads the Heater as O/C
On-line data confirms the heater pins that I can measure OK in practice (the two pins at the bottom in the attachment)
Could it be that the different suffix (N to P) is relevant ?
Does anyone have the correct settings for the AVO tester?
Thanks
ID:	241562   Click image for larger version
Christoffrad is offline
Old 18th Sep 2021, 12:14 pm   #2
ms660
ms660's Avatar
Default Re: PE06/40N - AVO valve tester settings
The heater pins on the PE 06/40P are 2 & 3.
The heater pins on the PE 06/40N are 1 & 5.
So far as I can make out it would be 254 130 000 for the PE 06/40N.
Lawrence.
ms660 is offline
Old 18th Sep 2021, 12:55 pm   #3
Christoffrad
Thank you Lawrence
C
