5th Sep 2021, 12:28 pm | #1 |
Uher 4200 Report monitor, recording problem
Hi All. I have a Uher 4200 Report monitor on hand, it is a 3 heads version with 2 round VU metres. Currently, playback is OK, but recording does not work. I can clearly near source sound through the radio/phono socket with both VU metres working when switch to "S", but no sound on "T", and no moving of VU metres. When I turn the recording level and input volume to maximum, very very tiny sound can be recorded on the tape. The input is my ipod6, using 3.5mm to 5 pin din (1,2,4), don't have a microphone. I have changed most of the capacitors on the mainboard. Both channels have the problem. Really don't know what to do next. only have a multimetre on hand. Maybe something wrong with the recording amplifyer? or the unit 800 on the schematic? Please give some advice, many thanks. Kevin
5th Sep 2021, 12:51 pm | #2 |
Re: Uher 4200 Report monitor, recording problem
Sounds like the bias/erase oscillator is not functioning.
Can you erase a previously recorded tape when set to record ? |
5th Sep 2021, 1:12 pm | #3 |
Yes, it can be erased
5th Sep 2021, 10:51 pm | #4 |
Has this arrangement with the Ipod worked previously?
6th Sep 2021, 1:55 am | #5 |
It is the first time. I tried from my computer and cellphone, but the same problem.
Now I can hear sound and VU moving both on"T" and "S" when pressing the record button only, but still cannot record when pressing the play + record buttons, the recording sound is very very weak, only can be heard under maximum volume. Maybe a bad recording head? |
6th Sep 2021, 11:54 am | #6 |
What does the very weak recording sound like? Good but just low in volume? Muffled? Distorted? Tinny? How would you describe it compared to the input signal?
6th Sep 2021, 12:17 pm | #7 |
as same as the input, but very very low in volume, with the VU metres no moving. Already turned the input and recording level to maximum.
6th Sep 2021, 3:09 pm | #8 |
Is this off tape while recording or just in playback mode?
7th Sep 2021, 1:12 am | #9 |
The weak sound is in playback, off tape is normal as input. Seems something wrong with the recording amplifier? Can both channels break at the same time?
7th Sep 2021, 10:21 am | #10 |
I suspect that you are picking up the wrong pins on the DIN socket rather than there being any defect in the recorder.
7th Sep 2021, 10:34 am | #11 |
I tried 1,4,2 and 3,5,2 but neither is working.
7th Sep 2021, 10:39 am | #12 |
The meters should move on both record and playback - this is a three-head machine. Obvious things first - give the heads a very thorough clean - you'll need to remove the small cover (two timy screws) first. See if that improves matters. The middle head's the record head, the right one's for playback.
7th Sep 2021, 12:42 pm | #13 |
Is playback of a known good recording good both in quality and volume ?
Is the record issue the same with automatic (ALC) recording ? As well as the heads also would be worthwhile giving the record switch contacts a clean. It is not impossible but not that likely to have a hard failure with both left and right channels either components or Record head. David |
7th Sep 2021, 3:36 pm | #14 |
Agreed - does it play a prerecorded tape well?
This doesn't have ALC as it's a stereo model. |
7th Sep 2021, 4:07 pm | #15 |
thank you all for your reply. it indeed plays prerecorded tape normally. Only recording issues. I have cleaned the heads and adjusted the azimuth, but seem helpless. The contact should be ok, because the red light is on when pressing down the record button. Are the L and R channels totally separated? Could be a unit or components that control both recording channels?
7th Sep 2021, 9:26 pm | #16 |
8th Sep 2021, 9:32 am | #17 | |
The Bias Oscillator produces the Bias signal for recording and the Erase signal for erasing. The fact that Erase is working Ok would normally also mean that the Bias signal for recording should also be good. But to 100% prove it, the relevant signals would need to be monitored on an oscilloscope. Could also be monitored (but to my mind less effectively) using a volt meter capable of reading the high frequency bias oscillator signals (most ordinary digital multimeters and analogue AVO type meters will not measure the high frequency signals). What is the history of the unit, was it purchased recently with unknown recording status or have you had it for some time and recording previously was working ? David |
8th Sep 2021, 2:26 pm | #18 |
Many thanks, David. I will check the HF generator first and report back later. the recorder is a new purchase with unknown recording function history, and some resoldering signs in the recording amplifier and related area.
9th Sep 2021, 11:05 am | #19 |
This is probably a very trivial suggestion, but are you sure the tape's the right way round? I speak from experience!
9th Sep 2021, 1:26 pm | #20 |
That is a good question. Please forgive my limited knowledge, there is some music previously recorded on the tape which I don't know by this recorder or others. I can hear that under the speed of 19cm/s. The side of the tape facing heads is in a darker colour than the other side. I tried to record on every four speeds, as well as swapped the reels in another running direction, but all failed. I once suspected it was a read-only tape, but have not got any info regarding this. Is it possible the tape has expired and only can be read but not recorded?
