10th Mar 2021, 9:47 pm | #881 | |||
Re: Non-working Commodore PET 3016
0 - Pin 16 1 - Pin 19 1 - Pin 12 1 - Pin 9 0 - Pin 6 1 - Pin 5 1 - Pin 2 |
10th Mar 2021, 9:49 pm | #882 | ||
I cut each pin above the motherboard and remove the carcass of the chip - it's a one-way process...
Then I de-solder each pin from underneath individually and remove each pin one by one - takes 10-15 minutes or so if I'm careful. Then I pop in a turned pin socket and solder that in from underneath. if I have lost a pad (which I don't do much nowadays), I use your trick of putting some wires through the hole before I put the socket in place. Then I go through the schematics and perform continuity tests for each pin to make sure I have an electrical connection before I put any chips into sockets. Colin. Quote:
10th Mar 2021, 9:50 pm | #883 |
Shortly after power on there should be activity on UF7-10 and UF8-10, before it becomes steady high level. This is assuming the 6502 is running the display clear routine.
If you are able to see activity on UF7-10 and UF8-10, then use the second probe to look at the data on BD0 to BD7, and then also on SD0 to SD7. I think you should see hex 20 the space character on both sets of data lines while UF7-10 and UF8-10 are at low level. This would be all data lines low except for SD5 and BD5 which should both be high. This is probably going to mean turning the power off and back on for each test. So do this with About 30 seconds between turn off and turn back on, don’t turn the power on and off quickly. Last edited by Mark1960; 10th Mar 2021 at 9:55 pm. Reason: Add note on power cycling |
10th Mar 2021, 9:52 pm | #884 | |||
Here's a page on PETSCII. the semi-colon is 3B which is 0011101 in binary
https://en.wikipedia.org/wiki/PETSCII Colin. Quote:
10th Mar 2021, 9:54 pm | #885 | |
UF7/10 and UF8/10 go straight high at power on to 4.08V and stay there.
Colin. Quote:
10th Mar 2021, 10:01 pm | #886 | ||
Actually yes you are correct I messed up my Pin numbers on UF9 for the signals...
0 - Pin 16 0 - Pin 19 1 - Pin 12 1 - Pin 9 1 - Pin 6 0 - Pin 5 1 - Pin 2 the can also be checked on the 6316 as well obviously But - you have probably worked that out by now... Quote:
10th Mar 2021, 10:15 pm | #887 | |
As Mark says, if the processor is succeeding in running ROM code one of the first things it will do is to clear the display RAM, so shortly after power-on or reset there should be a series of writes to the display RAM. From what you say there is no write activity to the RAMs during the start up phase, but in that case I would expect the content of the RAM to be random, and for the screen display to be a random jumble of characters instead of one repeated character. Rather than destroy the RAMs at this stage, one possible approach is to replace / socket the latch UF9 and the buffers UE7 and UE8. With these made removable you will be able to scope what's coming out of the RAMs with nothing else connected to the SD0-SD7 bus. Any other ideas are welcome - basically, I'm looking for ways to prove that the RAMs are / are not OK without taking them out. |
10th Mar 2021, 10:16 pm | #888 |
Here's what I have:
1 - pin 2 1 - pin 19 0 - pin 5 1 - pin 16 1 - pin 6 1 - pin 15 0 - pin 9 0 - pin 12 I can see the 111011 pattern in reverse. Is that how it's supposed to work with the address lines/PETSCII? Colin. |
10th Mar 2021, 10:25 pm | #889 |
Yes that looks right, D0 is least significant bit and D7 is most significant bit.
10th Mar 2021, 10:34 pm | #890 |
I think Colin reported earlier that pins 11 to 14 on both ram chips were always high, but he has 3B on the output of the video latch. If this is confirmed then I think we can suspect the video latch is faulty and could be removed as the next step, to see if that also changes pins 11 to 14 on the ram chips.
10th Mar 2021, 10:37 pm | #891 | |
Thanks. I keep learning bit by bit.
No idea how to fix things, but I can do diagnostics. Colin. Quote:
10th Mar 2021, 10:48 pm | #892 | |
Removal and replacement of UF9 in a socket sounds like a cautious first step. That will also allow the possibility of manually applying different character codes to the outputs of UF9 to see if the expected characters are displayed. However, this doesn't really explain why there are steady highs on the outputs of the RAMs / inputs to the latch, unless those highs are somehow back-driving out of the UF9 inputs. If it's not the RAMs themselves which are supplying those steady highs, then the outputs of UE7 / UE8 are another possible source. |
10th Mar 2021, 11:16 pm | #893 |
I have sockets and replacement ICs here for UE7/8 if you think it's worth replacing them.
Is your first suggestion for me to remove UF9 and resocket/replace it? if so I have already purchased this from Cricklewood in anticipation and I have the sockets here: https://www.cricklewoodelectronics.com/74LS373.html I can also purchase TMM314APL from eBay for £3.00 ea (if they're the right ones): https://www.ebay.co.uk/itm/TMM314APL...IAAOSw7FBgMmcK Colin. |
10th Mar 2021, 11:37 pm | #894 |
TMM314APL-1 may be too slow, the 6114 is 90ns.
11th Mar 2021, 12:00 am | #895 |
In the first instance, since you have been so foresighted, try replacing UF9 only. Let us know if that makes any difference and we will take it from there.
11th Mar 2021, 12:08 am | #896 |
That bit pattern looks like a semicolon, alright. 00111011 = &3B = decimal 59 = PETSCII (and ASCII) semicolon character. No surprise you'd get a screen full of semicolons.
With UF9 removed, I would expect the inputs it drives to float high and, if I read my PETSCII right, give a screen full of a checkerboard pattern.
11th Mar 2021, 12:22 am | #897 |
I don't know whether or not it helps at all but you get the checkerboard pattern (see attached) with the 2001-8 when both video RAM chips are removed. The video RAM/ROM circuit is very similar.
Alan |
11th Mar 2021, 12:24 am | #898 | |
In addition to which, it should be possible to pull some of the lines low to fill the screen with known characters, to check that the char gen is working as expected. |
11th Mar 2021, 12:39 am | #899 |
Ok. I'll get the old chip out tomorrow and the socket in ready. The replacement may not come until Monday but I'll put a post up when it does.
Thanks to you in the main and with the help of the others who have contributed, I've got characters on my screen today. I'm very happy tonight. Thanks. Colin. |
11th Mar 2021, 9:02 am | #900 |
The more PET-specific this gets the more I will have to fade into the background, that is when you will really need the help of those individuals who know the machine better. It has been good to be able to assist to get it to this point though, and it now seems inevitable that the machine will eventually work as long as you continue with the same level of dogged determination that you have so far. With the combined knowledge and effort of all the people here combined, I can't see it not working in the end.
