Old 1st Nov 2008, 12:15 am   #1
yesnaby
yesnaby's Avatar
Default Midget Motorola 56A (USA)
Hello,
There was minimal restoration done on this radio, which I had from Wootton Bassett in 2007. The photos are probably the most interesting part!
This red beauty measures less than 7 inches wide and contains five mains-type valves in a superhet configuration. Originally it was for 110V but someone has added a resistive dropper so that it can work on 220/240V.
I had some trouble getting the chassis into and out of the cabinet and one of the interior plastic long studs fractured, not surprising for something made in 1955. I mended this with araldite. The tuning dial was stiff, but cleaning and oiling the bearings has not helped much.
Incidentally the tuning dial is a little crazy, you multiply the marking by 100,000 to get the frequency (MW only). The volume dial has no marking at all.
Apart from the usual cleaning and use of switch cleaner, I did not change any components or valves since it all seems to be working well.
Michael
ID:	20988   Click image for larger version
ID:	20989   Click image for larger version
yesnaby is offline
Old 1st Nov 2008, 12:54 am   #2
Jimmyhaflinger
Jimmyhaflinger's Avatar
Default Re: Midget Motorola 56A (USA)
Michael
most if not all American radios have this kind of marking on the dial, your also has the two CD (civil defense) triangles on the dial.
Jimmyhaflinger is offline
