Old 28th Mar 2018, 2:42 pm   #1
vinrads
Default The dreaded green spot on Midwest speaker
Having restored one of these , I could not resist it when a chassis came up on EBay fast forward a few month I decided to check the speaker to find that the energising coil was o/c , Ed kindly rewound it for me some ten thousand turns, but it came out a bit lower resistance than quoted in the circuit.
This is no ordinary speaker it has two coils the second one it tapped, after re assembling the speaker a thought came to me supposing the coils were connected wrong causing the magnetic field to cancel, how did I find the correct way, well I plugged the speaker into the chassis, switched on and was greeted with fantastic sound loads of volume.
I needed to prove my theory so fixed up a changeover switch as to reverse the two connections to the coil, the results were immediately much lower volume.
Next job is to restore the second chassis, pic of previously restored chassis. Mick.
vinrads is offline
Old 4th Apr 2018, 9:47 am   #2
jmedley
jmedley's Avatar
Thumbs up Re: The dreaded green spot on Midwest speaker
This looks a very interesting piece of kit, could you post more information re make and model, with more pictures of chassis
Thanks
Jim
jmedley is offline
Old 4th Apr 2018, 10:06 am   #3
vinrads
Default Re: The dreaded green spot on Midwest speaker
Hi Jim can I refer you to a previous post:-
https://www.vintage-radio.net/forum/...d.php?t=134775
As the first chassis had some rust I decided to strip it totally this took a while and loads of diagrams, but it was worth it, the second chassis I have is not too bad so I have just restored it electrically. I am looking for a suitable cabinet, or when I have time I intend to make one. If you want to see some Gorgeous radios Google Midwest Radio Museum.
Mick.
vinrads is offline
Old 6th Apr 2018, 8:47 am   #4
jmedley
jmedley's Avatar
Thanks Mick
jmedley is offline
