7th Nov 2018, 9:37 pm | #81 | |
Re: Electrical Waste, signs of change perhaps?
I've used contacts from a dead VT52 keyboard to repair some of the other machines. |
7th Nov 2018, 9:47 pm | #82 | |
The later one on the PC/AT was actually a membrane switch keyboard. The 2 layers of membrane were pressed together by the plastic flap that was part of the buckling spring mechanism. This type is a lot less reliable than the capacitive one. One of the nicest key'switches' I ever saw was magnetic. Insider were 2 wire loops coupled by a ferrite bead. There was a magnet on the keystem that was normally next to the bead. The magnet was strong enough to saturate said bead. You sent a current pulse through one of the loops and looked for an induced voltage in the other one. With the key 'up', the magnet saturated the bead so the current pulse couldn't increase the magnetic flux in the bead. So no output in the sense loop. Press the key, the magnet was moved away, the 2 loop were now effectively magnetically coupled by the non-saturated bead. Used on the HP9845 (and other machines...) Then there's the keyboard using transformers made of spiral PCB tracks used on the HP9810 and HP9820 machines. Oh and the electromagnetically encoded ones used on the Termiprinters. But those can wait for another day/thread! |
8th Nov 2018, 1:56 pm | #83 |
See the attached page from Electronics Weekly, August 15th.
I tried to find an online link without success. I then looked for any copyright claim in the printed issue - couldn't find one! So I feel hopeful that posting the photo won't cause any trouble. |
8th Nov 2018, 2:12 pm | #84 |
They are discussing on Radio 2 at present a proposed change in the law by Michael Gove to allow people to go through council tips and remove items to re-use - hope it goes through!
Steve. |
9th Nov 2018, 5:47 pm | #85 |
Yes I agree, but I did read one member was against this on H&S grounds, I’ll be interested to follow this debate.
Cheers John |
9th Nov 2018, 6:00 pm | #86 |
Well done Michael Gove if it goes through, I never cease to be amazed at the amount of perfectly good stuff thrown out or just needing minor repair at our local dump but you're not allowed to have it on some spurious H&S grounds.
There was also some interesting reading on the culture in Finland where they have much less of a throwaway culture. see here https://www.bbc.co.uk/news/science-environment-46099418 Chris |
9th Nov 2018, 6:24 pm | #87 | |
“What about the cowboys?” you cry. Almost by definition, cowboys ignore the rules. So an H&S crackdown will only crack down on the majority (important word) of responsible people, who either have the nous to repair stuff, or have the nous to know they can’t. We can’t womble at the tip. But we’ve been able to womble on ebay (spares/repair) for many years. How many shocks and fires can we directly attribute to a wombled appliance in these days of RCDs and double-insulated devices? At the same time, how many thousands of appliances have been condemned to landfill for one cracked solder joint, or a loose ribbon cable? Instead of a ‘stick’ approach, why not a carrot? Yes, you can scavenge at the tip, but produce a PAT tester cert., or cut the appliance cord off so the thing requires some level of knowledge to repair, and can’t just be flipped on again in an unknown state? |
9th Nov 2018, 7:16 pm | #88 |
Interestingly most microwaves I have disassembled do seem to be designed with repair in mind. For example on the turntable motor is on the underside and inaccessible without a lot of disassembly, but there's usually a pop-out section on the base. It's just part of the pressing and not used in production but you can snap the sheet metal, change the motor through the resulting hole, and then it's designed so you turn it around, slide the tabs in and secure it with a single screw. I'd say more than half the microwaves I've seen have that feature.
9th Nov 2018, 7:31 pm | #89 |
I wonder how many microwaves are floating around with only one screw on the motor?
