22nd Nov 2018, 4:46 pm | #201 |
Re: Electric clocks running slow warning
I've analysed historic frequency data on the National Grid website, which gives a frequency reading every second, to work out the deviation in 'grid time' error over the last two years.
I found a blog where some horologists visited the NG Control Room and there's a photo of a screen showing the time error as being -4 seconds at 17:20 on 11/6/16. Using Excel and the NG frequency data, I've compared how many seconds a clock actually 'counted' since then and the number of seconds it should have counted. I've checked up to Jan '18 so far and the grid time error was as follows at these points: mid-Sep '16: -67 seconds mid-Dec '16: -76s mid-Mar '17: -133s mid-Jun '17: -205s mid-Sep '17: -256s mid-Dec '17: -224s I was surprised at how 'out' it was and doubted my calculations, but the average frequency over the entire period is slightly below 50, implying the slowdown shown is correct. I note it starts to correct itself at the end of 2017. Also, in Jun '17, I tweeted the NG control room and asked what their current grid time error was and they said -7 minutes! They said it was unusually high, but that doesn't tally with my calculations above. I wonder if they gave me the wrong reading. |
24th Nov 2018, 12:28 am | #202 |
7 minutes does sound like a mistake, misunderstanding, or typo.
There is no generalised shortage of generating capacity in the UK at present. Any short term problems caused by breakdowns should be easily recoverable by very slightly increasing the frequency afterwards. Synchronous clocks are less used than in the past, but there still quite a few, and a loss of 7 minutes would be most noticeable. |
26th Nov 2018, 12:12 pm | #203 | |
mid-Mar '18: -430 seconds mid-Jun '18: -480s 20 Nov '18: -436s The substantial slow down between Dec '17 and Mar '18 reflects what posters said here about a slow down in early 2018! It means SEVEN minutes has been lost since 2016 and hasn't been made up. The table below shows an extract of what I've done. There should be 1,000,000 seconds between each of the dates below. The column on the right shows how many seconds passed based on grid frequency. This assumes 50.00Hz for 1 second = 1 second, so 49.9Hz for 1 second = 0.998 seconds. Is my calculating correct? 2018-01-16 07:06:38 +0000 1000012.535 2018-01-27 20:53:18 +0000 999933.8653 2018-02-08 10:39:57 +0000 999952.185 2018-02-20 00:26:37 +0000 999973.1144 2018-03-03 14:13:16 +0000 999983.2907 2018-03-15 03:59:56 +0000 999998.2501 2018-03-26 18:46:36 +0100 999983.658 2018-04-07 08:33:15 +0100 999993.9784 2018-04-18 22:19:55 +0100 999991.3088 2018-04-30 12:06:35 +0100 1000018.474 2018-05-12 01:53:14 +0100 999966.2587 2018-05-23 15:39:54 +0100 1000003.64 |
6th Apr 2020, 7:54 pm | #204 |
My synchronous mains clock suddenly went 2 minutes slow on Sunday morning, no sign of it catching up yet.
Paul's link to http://www.gridwatch.templar.co.uk/ shows the real-time frequency, now up to ~50.1 but about 7pm it was something like 48.9. I thought the demand was at an all-time low during the shut-down of businesses and transport?
- Julian It's good here |
6th Apr 2020, 9:22 pm | #205 |
As regards frequency I reset both clock-radios when we moved to BST and haven't noticed anomalies yet (although i have only checked mains frequency using a hand-held a couple of times)
I am finding the voltage here to be very stable, and very correct, over the last two weeks. Dave |
6th Apr 2020, 9:28 pm | #206 |
Over the past couple of months I had been checking my mains electric clock against the pips preceding the 9.00AM news on Radio 4. The clock has varied from about 10 seconds fast to about 40 seconds slow, relative to when I started, but I have no absolute reference to calibrate the mains frequency time against. I haven't checked since adjusting for summertime.
6th Apr 2020, 9:34 pm | #207 | |
6th Apr 2020, 10:30 pm | #208 |
I have several synchronous clocks now, and I leave several of them (the ones in my radio shack) set to GMT, so I didn't pay a lot of attention to what time they were showing when I reset everything else a week ago. However I have now adjusted the two with sweep seconds hands to indicate the exact time, and will keep an eye on them as the days go by.
Sorry, that sounds as if I have nothing better to do than watch time passing, which is far from the truth...!
7th Apr 2020, 12:22 am | #209 |
According to this site the average frequency for the past 24 hours was 49.98Hz
http://mainsfrequency.uk/fm-last10m |
7th Apr 2020, 12:59 am | #210 |
Thanks for posting the link to that frequency monitor I will do a comparison between my own frequency meter and it tomorrow, but the meter's behaviour looks the same as what I've observed before in terms of rate of change etc
7th Apr 2020, 8:33 am | #211 |
Yes, thanks Bill. As well as the real-time and historical displays, there's a lot of very interesting information on that website.
7th Apr 2020, 12:46 pm | #212 | |
There should be 4,320,000. So that's 1,628 cycles missing. This would move the seconds hand by 32.56 seconds, so, half a minute slow ties up with the observations. |
7th Apr 2020, 3:57 pm | #213 |
Guess I should use the time to make the effort to get my inverter telemetry back online since the server packed up ..... I suppose the mains frequency could be of interest to someone!
7th Apr 2020, 4:24 pm | #214 |
Two of my non-self starting synchronous clocks stopped simultaneously at just after 12.30 today, but another kept going, along with the kitchen appliance clocks. Around this time, the frequency had risen quite rapidly, but there's no obvious reason why two synchronous motors would have lost sync and stopped as a result.
Phil Optimist [n]: One who is not in possession of the full facts Last edited by Phil G4SPZ; 7th Apr 2020 at 4:29 pm. Reason: Update |
7th Apr 2020, 5:41 pm | #215 |
We used to rely on the frequency for easy time keeping. Maybe it's time! to reconsider. The short term variability can only get worse as rotating mass is gradually replaced by renewables. Radio-controlled clocks are now commonplace.
7th Apr 2020, 6:07 pm | #216 |
My SunDial clock keeps perfect time. Its Solar powered, y'know.
Richard |
7th Apr 2020, 8:42 pm | #217 |
It's pretty impressive, really, that a VCR-sized box can take any random voltage DC and convert it to AC precisely in step with whatever is already there, handling about ten or twenty times as much power through it as it could comfortably dissipate; yet "let go the rope at once if it sees nothing pulling on the other end" for the benefit of anybody working on the mains side.
I suppose it's basically an arbitrary function generator with a thwacking great class D amplifier tacked on the output, with the twist being that it determines what it's supposed to generate by sampling the existing waveform while the PWM output is off ..... I must see how mine handles a loss and reconnection of mains. (It's handled loss of DC every night and re-establishment every morning, so that's less interesting ) There are big, scary isolator switches -- black and white on the DC side, yellow and red on the AC side -- right next to it in the loft, so I could have a look one Lunchtime while it's got plenty of DC available!
7th Apr 2020, 9:42 pm | #218 |
Trickie Dickie, I would wager that if you go out and check it in the next couple of hours, it will be reading incorrectly!
I am afraid LUNAR time makes a solar device look silly. You should have a good clear but incorrect time if you check it. Les. |
7th Apr 2020, 10:26 pm | #219 |
I checked my meter against the one on the site and the two are exactly in sync which is good
8th Apr 2020, 12:14 am | #220 |
Agreed, but I have three of them and only one appears to stay in step with 'true time' all the time. The other two seem to drift randomly and re-synchronise every now and again. It's only a few seconds, granted, but seconds count when we're counting mains cycles.
I downloaded a free app for the smartphone (many are available) which provides a clear analogue display with sweep seconds hand, and that seems accurate.
