19th May 2020, 7:59 pm | #341 |
Re: Fixing a GEC BT 302 Television
Photos of pots are on post 261
19th May 2020, 8:25 pm | #342 |
Is it not a good idea if you show a picture of the back of the circuit board The printed circuit side so your soldering can be checked.
Have you watched the video John has on YouTube of the 302
I bet that car doesn't have a suppressor. |
19th May 2020, 8:30 pm | #343 |
Ok ill send a picture. No, I have not do you have a Link
19th May 2020, 8:46 pm | #344 |
Heres the soldering
19th May 2020, 9:11 pm | #345 |
19th May 2020, 9:19 pm | #346 |
I’m not sure is I’m not up to date on this tv but it looks to me that you might of bridged the tracks . Double check . As I’m looking at the picture it’s about 3/4 of the way up. And slightly in from the support bar . Maybe someone else can give a second opinion
19th May 2020, 9:21 pm | #347 |
I should have said on the right hand side.
19th May 2020, 9:28 pm | #348 |
Do you mean here
19th May 2020, 10:02 pm | #349 |
Yes that’s the place . If you have the access Solder must be removed. Be careful not to Heat it for to long or you might lift the track.
19th May 2020, 10:03 pm | #350 |
It looks like its crossed but it's not
19th May 2020, 10:09 pm | #351 |
Just saying it looks like it. If your convinced it’s ok then carry on . If your unsure check it with a meter for a short .
19th May 2020, 10:25 pm | #352 |
I'm new to this do you mean continuity on board
19th May 2020, 10:25 pm | #353 |
20th May 2020, 12:17 am | #354 |
Ok now the whole screen is illuminated line through the middle it's flashing, also has snow. No sound yet. I can now hear clicking sounds like it's coming from the transformer
20th May 2020, 9:46 am | #355 |
We need a picture Daz. Don't use the flash. Adjust the height and form controls to just fill the screen and turn the brightness on full. Is it just faint clicking sounds? It might just be static around the EHT rectifier valve box. What do you mean by 'line through the middle' if you have a full screen? What effect does the vertical hold have? John.
20th May 2020, 10:16 am | #356 |
It still has a bright horizontal line through the middle. But this time the whole screen is illuminated. I haven't changed the vert just yet. The one I have is 100uf
20th May 2020, 10:44 am | #357 | |
20th May 2020, 10:47 am | #358 |
I did I fixed that.
20th May 2020, 11:15 am | #359 |
will I need to add that vert switch in? that must be the problem we have horizontal. but no vertical. Thats what I've been reading about.
20th May 2020, 11:59 am | #360 | |
Take some good, clear off-screen pictures and answer John's questions! Unless and until you do, we can only guess as to what the actual fault(s) and next step(s) might be. |
