Old 23rd Apr 2019, 8:56 pm   #1
Steve G4WCS
Steve G4WCS's Avatar
Default RF power transistor testing
Picked this bargain/money pit up for less than the price of the heatsink. Someones gone to a lot of thought with this then spoilt it by tacking bits on like an afterthought
I'm going to give it a full rebuild. I don't like the rats nest biasing circuits, and I'm thinking of using the LM723 bias circuit as per the Motorola application note.
I'm hoping the power transistors aren't fried but I'm working on the assumption that they are.
What's the recommended way to test them, just checking for shorts/open circuits and checking the diode junctions, any precautions etc?
Thanks
ID:	181737   Click image for larger version
ID:	181738   Click image for larger version
Steve G4WCS is offline
Old 23rd Apr 2019, 10:10 pm   #2
Steve G4WCS
Default Re: RF power transistor testing
Made a start. Cif bathroom cleaner. Never known anything like it to lift dirt.
Also isn't the internet wonderful. Couldnt' find any info on it so googled 140 watt push pull amplifier and found this.
ID:	181746   Click image for larger version
ID:	181747   Click image for larger version
Old 23rd Apr 2019, 10:48 pm   #3
Steve G4WCS
Thinking about it after a beer, should I just reassemble it as is first off then give it a sniff of rf and see what it's doing or not ?
Old 24th Apr 2019, 3:53 am   #4
Terry_VK5TM
Terry_VK5TM's Avatar
I found what I think is the original auction listing for it - definitely says not working, so another beer and a bit more thinking may be in order.
That amp is probably straight out of one of Motorola's app notes if you can find it.
Terry VK5TM
https://www.vk5tm.com/
Terry_VK5TM is offline
Old 24th Apr 2019, 9:21 pm   #5
Steve G4WCS
Terry. Over here most radio/cb type equipment is listed as not working to cover the sellers from bad selling experiences. The last cb linear I bought as a non worker was fine when tested.
Stripped it down and these are the components that will be changed as a matter of course. I can now get at it to perform resistance and voltage checks. Nothing appears to have let magic smoke out
The heatsink has been snook into the dishwasher.
ID:	181797   Click image for larger version
ID:	181798   Click image for larger version
Old 29th Apr 2019, 4:40 am   #6
Argus25
No Longer a Member
........hmmm I thought I read on a thread somewhere that somebody else did this, perhaps they had a lot of, or a high concentration, dish wash powder (which is very alkaline and attacks anodizing and aluminium) and it spoiled the nice black anodizing on the heatsink. But you may be ok if the solution is weaker and/or temperature lower and not get any issues. It might be better to do it by hand with a trace of the friendly hand dish wash and a small soft brush.
I found the thread:
https://www.vintage-radio.net/forum/...d.php?t=139689
Argus25 is offline
Old 29th Apr 2019, 12:47 pm   #7
Steve G4WCS
It survived the dishwasher, but has had a coat of satin black anyway
ID:	182096   Click image for larger version
Old 29th Apr 2019, 1:11 pm   #8
Argus25
No Longer a Member
......just a thought possibly not a wonderful idea to spray the surface where the transistors screw down with spray paint, as it is not a wonderful thermal conductor.
Was the anodized finish damaged at all in the dishwasher ?
Argus25 is offline
Old 29th Apr 2019, 1:29 pm   #9
Steve G4WCS
I haven't, I've only painted the visible elements, and no.
Old 3rd May 2019, 11:15 pm   #10
Steve G4WCS
rebuild started. Old tantalums and elecs are going. A couple of old 15 ohm carbons have drifted away so will be replaced.
ID:	182409   Click image for larger version
ID:	182410   Click image for larger version
Old 3rd May 2019, 11:43 pm   #11
Oldcodger
What's the recommended way to test them, just checking for shorts/open circuits and checking the diode junctions, any precautions etc ?
Thanks
AVO on ohms . Junction test/DVM on diode test. if inconclusive, isolate base ( if possible ) for further testing.
Oldcodger is offline
Old 4th May 2019, 10:42 pm   #12
Steve G4WCS
Pet hate 1. Untidy wiring
Pet hate 2. Non flux removal
ID:	182486   Click image for larger version
ID:	182487   Click image for larger version
ID:	182488   Click image for larger version
Old 17th May 2019, 11:03 am   #13
Steve G4WCS
It lives.
Haven't tried it at full power levels as I hadn't put thermal compound on the power transistors
https://youtu.be/Dy_cqqq89xI
I've added a small computer fan to it as there are some parts inside that get warm and aren't heatsinked, I used a riding helmet bag for filter material as it's very breathable
It's quiet enough
https://youtu.be/WT7t1fq6Kc8
Plan is to use it with the IC-251 which has a Mutek front end.
Should make quite a good setup
ID:	183266   Click image for larger version
ID:	183267   Click image for larger version
ID:	183268   Click image for larger version
ID:	183269   Click image for larger version
Old 17th May 2019, 12:03 pm   #14
Refugee
Refugee's Avatar
A riding helmet bag sounds expensive.
I normally use a vacuum cleaner motor filter. They are made to be cut to size.
I just linked to the first one on a search. Wilco stopped stocking them for some reason.
https://www.amazon.co.uk/Universal-V.../dp/B004A8JMSE
A cheaper one.
https://www.amazon.co.uk/dp/B078VTCW79/ref=dp_cerb_1
Refugee is offline
Old 17th May 2019, 12:15 pm   #15
Steve G4WCS
A cheaper one.
good shout.
the helmet bag was being cleared out anyway but I spotted its potential
