Old 25th Sep 2021, 12:03 pm   #1
paolo
paolo's Avatar
Smile Philips GF22103 Help Please
Hi Everyone,
It has been a while since I posted because I haven’t had any projects for quite a while. However I picked up a non-working Philips GF22103 record player today. It is the 1970’s equivalent of the Disc Jockey battery operated portables. I had an orange one in 1974 and couldn’t resist this one when I saw it.
It wasn’t working when I collected it. No motor power although the amp was working. Replaced the motor BC148 with a BC549C and all is well apart from crackling/static when the motor is running. The noise is the same no matter the volume.
Any ideas? I haven’t changed any of the caps. The noise goes away when I advance the turntable by hand, gets worse when I slow the turntable by hand (motor running of course).
Thanks in advance for any and all suggestions!
Paul
paolo is offline
Old 26th Sep 2021, 7:24 am   #2
paolo
paolo's Avatar
Default Re: Philips GF22103 Help Please
Thought I should add some pictures. I have changed the capacitors but it hasn’t made any difference. Interestingly though there’s a variable resistor that adjusts turntable speed. When slightly slow there is no crackling/motor noise at all. When set to the correct speed the noise comes back. Adjusting the volume makes no difference.
There are three germanium transistors: an AC187 in the motor circuit plus an AC127 and an AC128 in the amp. I’ve not touched those because I don’t yet have any replacements nor means of testing them.
Paul
ID:	242150   Click image for larger version
ID:	242151   Click image for larger version
ID:	242152   Click image for larger version
ID:	242153   Click image for larger version
paolo is offline
Old 26th Sep 2021, 8:08 am   #3
Records
Records's Avatar
try replacing that variable resistor
Being me is easy, its the image thats hard..ELVIS
Records is offline
Old 26th Sep 2021, 8:56 am   #4
Herald1360
Herald1360's Avatar
Hmmmm.... crackles.....Lockfits......
Maybe replacing those BC148s and that BC149 with BC108s and BC109 might help. The BC149 could be most suspect since it's likely to be the first in the signal chain.
For a quick trial, pretty much any NPN Si small signal device could be used.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 26th Sep 2021, 9:10 am   #5
paolo
paolo's Avatar
Don’t have a replacement but have cleaned it with DeOxit. Slightly better but the noise is still there. Also, I was mistaken, the noise is there at any position.
paolo is offline
Old 26th Sep 2021, 10:09 am   #6
paolo
paolo's Avatar
I have BC549s and 550s. Swapped out the 148s and the 149 but the crackle remains the same! Thinking it could be the AC187 in the motor circuit generating noise.
paolo is offline
Old 26th Sep 2021, 11:07 am   #7
paolo
paolo's Avatar
Update: I am going to call time on this until I can replace the germanium’s in the amplifier. On 60s mono singles there is lots of volume but on later LPs and singles there’s a lot of noise and distortion. I have some on order but who knows when they will arrive!
paolo is offline
Old 26th Sep 2021, 11:36 am   #8
Herald1360
Herald1360's Avatar
The noise could be brush sparking perhaps? Are there any suppression caps about it?
....__________
Old 26th Sep 2021, 12:52 pm   #9
That points to the centrifugal governor in the motor, stick a 100nF cap across the motor. The govenour is on the motor armature and (usually) switches off just one winding, hence the pot to get it just above speed.
Old 26th Sep 2021, 6:41 pm   #10
ben
ben's Avatar
Excellent tip from Chris and Merlinmaxwell. Motor noise seems fairly common on this series of machines with the centrifugal governor.
Last week I repaired a GF110 which is slightly earlier than yours. That had leaky/tin whisker germanium transistors in the amp, so reduced volume and harsh sound. making a new heatsink for one of them provided a (temporary?) cure.
Regards,
Ben.
ben is offline
Old 27th Sep 2021, 5:01 am   #11
paolo
paolo's Avatar
Excellent suggestions indeed Ben. Thank you Chris and Merlinmaxwell, the cap across the motor did the trick. Obvious in retrospect! Wonder why Phiiips didn’t fit one as a matter of routine? Probably to save the 0.001p per device! I changed the remaining 548 as it was the only one I hadn’t and now have plenty of gain in the amp. There’s still distortion though so I will report back when I get my replacement 127 and 128.
Thanks all,
Paul
paolo is offline
Old 9th Oct 2021, 10:41 am   #12
paolo
paolo's Avatar
Quick update on this. I am pleased to report that it is working really well now that the AC127 and AC128 output transistors have been replaced. The final issue was related to a dodgy GP200 cartridge that I thought was good but wasn’t. New one fitted and the job’s done! Thanks for all of the help and assistance!
Paul
ID:	242979   Click image for larger version
ID:	242980   Click image for larger version
paolo is offline
Old 11th Oct 2021, 5:34 pm   #13
ben
ben's Avatar
Good news!
Don't throw out the old head - it is quite easy to gut it and fit a Chuo Denshi clone cartridge into it. I have done this many a time. More recently I had some success by actually just replacing the internal ceramic element. One of these days I will make a thread on the subject.
Regards,
Ben.
ben is offline
Old 12th Oct 2021, 2:11 am   #14
hayerjoe
hayerjoe's Avatar
Originally Posted by ben View Post
Good news!
a +1 vote for the thread from me Ben!
hayerjoe is offline
Old 12th Oct 2021, 4:03 am   #15
paolo
paolo's Avatar
Good news!
No danger of that Ben! It is already in my spares box awaiting its autopsy
paolo is offline
