Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets, Parts and Service Information Wanted (private buyers only, no swaps)
Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps.
Reply
Old 25th Sep 2021, 4:51 am   #1
LA9CHA Thorvald
Default Trafo laminations
How to determine if oxidation of transformer lamination (EI-33) is ok after burned out windings. Has been very hot, enamel burned partly off! Eventually how to check?
LA9CHA Thorvald is offline   Reply With Quote
Old 25th Sep 2021, 5:23 am   #2
joebog1
joebog1's Avatar
Default Re: Trafo laminations
A picture tells a thousand words. BUT, if its only burned from overlaod the iron should still be OK.
Joe
joebog1 is offline   Reply With Quote
Old 25th Sep 2021, 11:00 am   #3
LA9CHA Thorvald
Joe
Ok Joe, as informed the lams have been so hot that the isolation and evt. paper has burned (probably no paper but oxidating lams). I will however give the lams a go and try! Tks for answer!
Thor vald
Old 25th Sep 2021, 11:08 am   #4
G6fylneil
Motor rewinders use special torches to "burn" out old windings and don't have problems.
G6fylneil is offline   Reply With Quote
Reply
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright ©2002 - 2021, Paul Stenning.
