Old 22nd Sep 2021, 4:52 pm   #1
bobhowe
bobhowe's Avatar
Talking Roberts BR added to my collection
Hi after getting a Roberts P4A radio discussed on another thread i have just bought a Roberts BA as David Boynes was telling me that the B7G Miniature valve sets are very good performers as well . It needs a power plug & on / off switch knob . I have downloaded from this site the 1123 Trader sheet that covers the CR mains and battery set as well as the BR battery only version but some of the component values are different to the BR on the Trader sheet here is some pictures of the set kind regards Bob
ID:	241946   Click image for larger version
ID:	241947   Click image for larger version
Kind regards, Bob.
bobhowe is offline
Old 22nd Sep 2021, 5:02 pm   #2
Default Re: Roberts BR Have I Gone To The Dark Side ?
Why the dark side? I had one of these, worked well, now at the Chiltern Open Air Museum in pride of place in the grown ups bedroom of the "Amersham Prefab".
Old 22nd Sep 2021, 5:23 pm   #3
bobhowe
bobhowe's Avatar
Hi Just a bit of fun never had a battery valve set till i got the P4D an did not know how really got they are kind regards Bob
Kind regards, Bob.
bobhowe is offline
Old 22nd Sep 2021, 8:54 pm   #4
FERNSEH
FERNSEH's Avatar
Hi Bob,
Here's a picture of the internals of my Roberts model CR, the mains-battery version of your model BR.
Note the different chassis metalwork employed in the two models. No holes on the chassis in the battery only version where the mains power supply components are fitted in the model CR. That's real quality.
DFWB.
FERNSEH is offline
Old 22nd Sep 2021, 9:08 pm   #5
bobhowe
bobhowe's Avatar
Yes David i agree the quality is really good the solder is great to work with no dry joints the components are easy to desolder no trying to pick out the wire that is wrapped round tag strips like other makes has any work been done on your set kind regards Bob
Kind regards, Bob.
bobhowe is offline
Old 22nd Sep 2021, 9:30 pm   #6
FERNSEH
FERNSEH's Avatar
The set was restored last year as a lockdown project. The actual receiver didn't need much work but special care was taken with the mains power section, with particular attention to the low tension supply.
Performance is excellent, receives BBC R4 on the long waveband loud and clear.
DFWB.
FERNSEH is offline
Old 22nd Sep 2021, 9:59 pm   #7
bobhowe
bobhowe's Avatar
DFWB.
Hi David did you put regulator in the power supply ? as looking at the trader sheet the low tension side would vulnerable to voltage spikes kind regards Bob
Kind regards, Bob.
bobhowe is offline
Old 22nd Sep 2021, 10:20 pm   #8
FERNSEH
FERNSEH's Avatar
"Hi David did you put regulator in the power supply ? as looking at the trader sheet the low tension side would vulnerable to voltage spikes kind regards Bob"
Hi Bob,
I didn't use an LM317 for the filaments. Tomorrow I'll take the chassis out and show the methods I employed to repair the power supply.
DFWB.
FERNSEH is offline
Old 22nd Sep 2021, 10:59 pm   #9
bobhowe
bobhowe's Avatar
Default Re: Roberts BR added to my collection
Thanks David that is a good idea if other forum members get the same set and it will save the valve filaments going OC if the low tension voltage gets high king regards Bob
Kind regards, Bob.
bobhowe is offline
Old 23rd Sep 2021, 10:20 am   #10
Herald1360
Herald1360's Avatar
With 5000uF and a choke in the LT supply, I doubt that spikes would be a problem, only longer term excess supply voltage. MRs tend to fail high rather than short too.
A series string of suitable diodes across the LT supply could provide the braces for peace of mind....
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 23rd Sep 2021, 6:18 pm   #11
bobhowe
bobhowe's Avatar
Hi without going OT my house mains voltage varies by about 7 volts sometimes it is high in the afternoon kind regards Bob
Kind regards, Bob.
bobhowe is offline
Old 23rd Sep 2021, 6:32 pm   #12
ms660
ms660's Avatar
I can't remember for parallel connected but for series connected the trick originally was to run them at 1.3 Volts to help guard them against being over run due to voltage fluctuations.
Lawrence.
ms660 is offline
Old 23rd Sep 2021, 10:02 pm   #13
Herald1360
Herald1360's Avatar
The same 1.3V would apply for parallel filaments. The difference being that (4 valve set assumed) a series filament string would have a total LT of 6.5V (3*1.3V + 2.6V) whereas the parallel filaments would simply have the 1.3V.
....__________
