Reply
Old 11th Sep 2021, 6:04 am   #1
Melvsals
Default Tandberg model 62/64
Hi All, I've been playing with an old Tandber reel to reel model 62 and realised the motor is running constantly. I've checked both micro switches one for the tape and one for the control lever and both read ok on test meter. I've traced the cable to the rear of the fuse holder and tested here. Not sure if wired correctly any help would be appreciated thanks ..Mel
Melvsals is offline   Reply With Quote
Old 11th Sep 2021, 8:10 am   #2
Ted Kendall
Default Re: Tandberg model 62/64
I think there is a suppressor capacitor across the motor switch - it may have gone leaky.
Ted Kendall is offline   Reply With Quote
Old 11th Sep 2021, 9:45 am   #3
DMcMahon
DMcMahon's Avatar
From Teds input I can see on the schematic that there is capacitor C13 (0.1uF/400V paper) in series with resistor R17 (51 Ohms 0.5Watt) across the motor switch & the automatic stop microswitch to act as suppressor (the components together are called a CR snubber in this case). Sometimes the CR components of the snubber are encapsulated in a single package, in this case it sounds like they are 2 discrete components
So quite possible that the capacitor has shorted and maybe also taken out the resistor.
DMcMahon is offline   Reply With Quote
Old 11th Sep 2021, 12:05 pm   #4
Melvsals
Thanks Ted and David I will check and update.
Great site and very quick response
Old 13th Sep 2021, 2:40 pm   #5
ben
ben's Avatar
In some tandbergs, this cap is located on the tag strip on the transformer where the motor switch/wires go, and not on the switch itself.
Regards,
Ben.
ben is offline   Reply With Quote
Old 14th Sep 2021, 10:40 pm   #6
ricard
ricard's Avatar
It's quite common for the snubber cap on these machines (and all Tandbergs of similar vintage) to fail short circuit. Not quite as bad as the Rifa caps which populate the rest of the machine, but not far off. Unlike a failing X2 cap, there are no fireworks associated with the failure, since the cap is mounted across a switch and not across a voltage source.
ricard is offline   Reply With Quote
Old 15th Sep 2021, 8:56 am   #7
Melvsals
Hi guys. Replaced the cap and resistor this morning and they presto works as it should. Thank you so much for your help.
Reply
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright ©2002 - 2021, Paul Stenning.
