25th Sep 2021, 2:00 pm | #1 |
Dial cord spring for a Grundig Satellit 650?
Hi, during the work to restoring a satellit 650, dial cord spring broke. Unfortunately no one of my spare parts dealer in Europe for Grundig radios have one, so I ask where i can find it. Dimensions are about 2,5 mm OD and about 15 mm lenght with hooks. I have searched on two suggested sites I have find here but minimal dimensions are bigger than I need...someone can help me?
Thanks in advance, F. |
25th Sep 2021, 9:52 pm | #2 |
Re: Dial cord spring for a Grundig Satellit 650?
If it has broken at one of the hooks, it should be possible to bend the end turn 90° to make a new hook. I have sometimes done this when no suitable replacement was to hand.
25th Sep 2021, 10:38 pm | #3 |
Retractable ball-point pens are a good source of all sizes of springs.
Cheers - Martin ZL2MC |
25th Sep 2021, 10:39 pm | #4 |
The spring from a retractable ball-point pen would be my starting point.
-- Graham. G3ZVT |
26th Sep 2021, 12:01 am | #5 |
Unfortunately has broken in three pieces...no way to recover it.
Hi, F. |
26th Sep 2021, 12:06 am | #6 | |
Hi, F. |
26th Sep 2021, 1:49 pm | #7 |
If you have a spring that has the right diameter size of wire, you might be able to wind your own spring, using the shaft of a twist drill as a mandrel. You would need to use a somewhat smaller drill as the wire will go back slightly. I have done this in an emergency, clamping the drill and one end of the wire together in the jaws of a vice before starting to wind.
27th Sep 2021, 6:12 am | #8 | |
F. |
