Old 17th Mar 2019, 11:39 pm   #1
Richard_FM
Richard_FM's Avatar
Default Using Canned Air For Removing Dust
Recently I've had to clean a lot of dust & fluff out of 2 devices, mostly using the suggested method of a clean paintbrush.
This has been useful, but sometimes I've not been able to get into some tight spots with it.
I did wonder if it was worth investing in a aerosol of compressed air intended for removing dust, as I wasn't sure how effective it was, and if it's too rough for cleaning PCBs.
Richard_FM is online now
Old 18th Mar 2019, 12:07 am   #2
GRID LEAK
Default Re: Using Canned Air For Removing Dust
Canned compressed air is perfectly safe for use on "MOST" electronic equipment. Just don't get too close to any delicate stuff. Its downside is the high cost of it. I use my garage compressor set to a lower pressure for cleaning purposes. A 12volt tyre inflator is a cheap and cheerful substitute, but it needs a 12volt supply to power it.
John.
GRID LEAK is offline
Old 18th Mar 2019, 12:26 am   #3
Richard_FM
Richard_FM's Avatar
Thanks for the advice, I've heard of using air compressors to clear dust, I have an electric tyre pump so I might see how I get on with it, though I'll have to work out how to power it as it has an in car power connector.
Old 18th Mar 2019, 1:03 am   #4
Reelman
Reelman's Avatar
I was surprised how effective the canned air was for cleaning, it can clean up far faster than a manual brush. Just be careful where you use it.
My boss was using it in the workshop to clean an old pc motherboard that was thick with fluff, dust etc. Whilst I was impressed with the speed and resulting cleanliness he was not impressed when I said he should have done it outside rather than fill our lungs with human dust which of course went everywhere!
Peter
Reelman is online now
Old 18th Mar 2019, 8:35 am   #5
stevehertz
stevehertz's Avatar
I use one of these. Expensive to buy, but as a rechargeable device it's a once only payment.
https://www.canlessair.com
stevehertz is online now
Old 18th Mar 2019, 10:41 am   #6
Nickthedentist
Nickthedentist's Avatar
Following on from what Steve advised, I have the mains powered version: https://www.metrovacworld.com/produc...uster/overview
Not cheap, but then have you seen the price of air duster aerosols these days?
Seriously, it's been worth every penny and has made cleaning out old chassis a joy. Just take them out into the garden, plug in the blower, bit of assistance from a big paintbrush if need be, and the job's done in under a minute. I also use it for computers, TVs, audio gear, the lawnmower, clock cases, lampshades and so on.
£85 on Amazon UK: https://www.amazon.co.uk/Metro-220-2.../dp/B003BZCOKK
N
Nickthedentist is online now
Old 18th Mar 2019, 11:12 am   #7
MrBungle
MrBungle's Avatar
I use an old airbrush compressor I got on gumtree for a tenner for this. That and a horse hair brush I stole off Mrs Bungle
MrBungle is offline
Old 18th Mar 2019, 11:14 am   #8
Nickthedentist
If you've got the space for a compressor, they're great too, though the air can be moist if you're not careful.
Old 18th Mar 2019, 12:08 pm   #9
Poundland do canned air, for a pound.
Old 18th Mar 2019, 12:26 pm   #10
The canned air, I assume, is aerosol propellant not actual air. So I'd be a bit concerned about what it is and where it comes from.
I have a compressor in the garage and the receiver (no, not that sort!) remains at about 150psi so I don't need to run it up to blow a bit of dust off anything. It really comes into its own for clearing sawdust out of the planer, router, etc.
But for things like rusty radio chassis, then a compressor also gives you the bead blasting gun option.
There isn't really enough utility in doing radio stuff to justify one, but if you already have one, or come across one for a low enough price, then it opens a whole new world.
Radio Wrangler is online now
Old 18th Mar 2019, 12:57 pm   #11
Dave Moll
Dave Moll's Avatar
I remember the late (and inimitable) Gerry Wells reckoning he could use his compressor to send woodworms flying from an infected cabinet - though maybe just a flight of fancy!
Dave Moll is online now
Old 18th Mar 2019, 1:35 pm   #12
Jonster
N
I've got one of those DataVacs too, they are excellent.
Jonster is offline
Old 18th Mar 2019, 1:57 pm   #13
kalee20
Personally I prefer suck to blow. Paintbrushes plus vacuum cleaner.
This will remove the majority of the dust, without spreading it everywhere in the vicinity! After that, if necessary, the compressed air comes out. Great for cleaning air-spaced tuning capacitors, but watch the pressure!
As to canned air, I have never used one, so can't comment. Less than the cost of a dinner out, though!
kalee20 is online now
Old 18th Mar 2019, 5:51 pm   #14
Restoration73
Restoration73's Avatar
Don't forget to use suitable personal protection e.g. goggles, dust mask etc.
Dust may contain chemical, radiological or bacteriological particles which in their mildest form could be an irritant, or have even more serious consequences.
Restoration73 is offline
Old 18th Mar 2019, 6:09 pm   #15
The very same dust we live in day to day, a bit OTT for a simple cleaning operation without extra chemicals.
Old 18th Mar 2019, 6:18 pm   #16
Tractorfan
Tractorfan's Avatar
Smile Re: Using Canned Air For Removing Dust
Hi.
Just a thought about using a compressor for blowing out muck: is there the risk of crank case oil vapour being emitted in the air? I don't think 'domestic' garage compressors have an oil separator. Or do they have piston rings that don't require lubrication?
Cheers, Pete.
Tractorfan is offline
Old 18th Mar 2019, 7:00 pm   #17
The piston rings are lubricated. Oil and water separators are normal for outputs used for paint spraying. Otherwise finishes are spoiled. Outputs used for air tools (drills, grinders saws) are sometimes provided with an oil injector. You have to take care to keep flexible hoses apart for clean and oily air.
Old 18th Mar 2019, 9:31 pm   #18
He kids not about dust, I speak from personal experience, no mask...I ended up in a very bad way within half an hour or so after exposure, sometimes it's not the dust per se but what's on it.
Old 18th Mar 2019, 10:09 pm   #19
vidjoman
Perhaps the answer is to use the lowest pressure to remove/loosen the dust and a vacuum system to suck up the debris.
vidjoman is offline
Old 19th Mar 2019, 8:05 am   #20
John M0GLN
John M0GLN's Avatar
There should be no problems with old valve radios, but could using paint brushes and dry air on any sensitive semi-conductor devices cause problems with static electricity?
John M0GLN is offline
