Old 15th Nov 2013, 8:23 am   #1
ssjenkins
Default Hameg 203-6 scope u/s
Hi All .
One of the members on another forum recommended this sub-forum so I'm hoping you can help.
I left my 203-6 on yesterday for an hour or so to warm up. When I returned I was greeted with a blank screen. On further investigation I've found that I seem to have lost the Time/Horizontal deflection. Here's some more details.
Power indicator lights up OK. All switches up, all controls at centre, except the calibrates. Nothing on screen. With probe connected to the 2V test signal and the "X-Y" button depressed I have a 2V vertical line indication on the screen. If I depress the "component tester" I have the expected horizonal indication on screen. There does seem to be a smell of a burnt component coming from it, although I haven't opened it up yet to have a look.
I have been offered a 303-6 for £180, but I'm not keen on throwing things out if they can be repaired at a reasonable price. Hameg in Barcelona have quoted me around £170 to fix mine??
Anywa , I'd appreciate any help and/or advice.
Sammy.
ssjenkins is offline
Old 15th Nov 2013, 10:13 am   #2
maninashed
Default Re: Hameg 203-6 scope u/s
Hi, you haven't given us a lot to go on here. Are you familiar with the working of a scope, and do you have a manual/circuit diagram? The manual is important when trying to repair a complex piece of test equiptment like a scope. So if you don't have a manual, I suggest you obtain one.
I'm not particularly familiar with the Hameg range of scopes, but from what you describe, eht is present, and you do have a trace, but no horizontal deflection.
This suggests a fault in the timebase/ x amp circuitry, but you will need to check voltages in this area and this is why you need the manual.
Bill
maninashed is offline
Old 15th Nov 2013, 12:31 pm   #3
ssjenkins
Hi Bill .
No , I've never had to fix a scope before so this will be a first . Saying that , I am reasonably competent and I do repair other electronic items . CB radios etc. I did repair a TV once , but it was with advice from another forum . I do have the standard manual for the scope which has the schematics in it . I will have a look around and see if I can find the dedicated service manual for it .
Just to clarify . You are correct in what you say . EHT and a vertical trace present , just no horizontal deflection .
Old 15th Nov 2013, 12:49 pm   #4
kernowcam
I found my Hameg Manual at their website. I needed to download the English one in full and the back end of the German one to get the diagrams.
I did call Hameg uk who did not help but put me through to Germany support who told me the scope was old, produced by Hameg and they are now Another company so the trail went cold.
I had an erratic trace on ch 1. Stripped the unit - which involved removing the case and the front panel, then kept digging till the modular board came out. Well made, switched well sealed up but managed to switch clean the required ones. All well since.
I was mindful of the 2000v in there and being a bit of a numpty tried to be careful.
Hope about a good visual and sniff test first?
Also check all the switched are out. That threw me when I reassembled mine.
kernowcam is offline
Old 15th Nov 2013, 12:54 pm   #5
maninashed
Sammy, primarily be careful re the high voltages present in scopes.
First, check all power supply rails are all present on the secondary of the psu, there will be several levels of voltage, some regulated. Some will be + and - rails (ie +12v and -12v). Make sure all are present and correct.
Second, check that the correct power supplies are present to the timebase circuit and X amplifier. The X amp is connected to the X deflection plates in the CRT.
Thirdly, using the circuit diagram, check that the correct voltages are present in the X amp. If you have access to another scope, this will be useful for fault finding further.
Bill
Old 15th Nov 2013, 1:12 pm   #6
ssjenkins
Hi All .
Well , a quick visual inspection has shown R541 melted on the Time Base board . It's got something to do with the 12V line . I've uploaded a few photos and the diagram .
Sammy
ID:	86036   Click image for larger version
ID:	86037   Click image for larger version
ID:	86038   Click image for larger version
ID:	86039   Click image for larger version
Old 15th Nov 2013, 2:12 pm   #7
Vicboduk
Hi Sammy, I don’t know how familiar you are with the triggering facilities of your scope but before you go any further do make sure that the trigger mode is set to “Auto” and not “Norm”.
This is a common pitfall for the uninitiated. If the trigger is in “Norm” mode a scope will only display a trace if it has something to trigger on and the level control is set correctly, otherwise it will display nothing.
Vic
Edit; I've just found a picture of your scope - I believe that the trigger mode button (AT/NORM.) needs to be out to select auto mode.
Edit,Edit; It looks like you definately have a hardware fault - It appears that you uploaded your pictures as I was composing my reply...
Vicboduk is offline
Old 15th Nov 2013, 2:25 pm   #8
maninashed
Well, you have a good clue there!. There is probably a transistor gone s/c associated with it. Unfortunately the resolution of the circuit diagram is not good enough for me to make out the component numbers and values. I will send you a personal message with an email address, and you can send me a scan of the circuit, and hopefully we can get this sorted.
Bill
Old 15th Nov 2013, 3:20 pm   #9
ssjenkins
Hi . Thanks to all . I appreciate the help . The diagrams are on their way Bill .
Cheers !
Sammy
Old 15th Nov 2013, 4:16 pm   #10
maninashed
Thanks for the circuit diagrams.
Ive had a quick look and cant find R541 on the diagram, but there are 2 x R540's so Im assuming that's a typo and the R540 on the right hand side is the resistor that's burnt up. If that's correct, check C529 for short circuit, T512,T513 and T514, one or more may be short circuit. Let us know the results.
Bill
Old 15th Nov 2013, 4:23 pm   #11
ssjenkins
Hi Bill . There's a delay every time I reply to a thread as a moderator has to approve each post . I've emailed you as R541 is in the first diagram . Regards
Old 15th Nov 2013, 4:36 pm   #12
maninashed
Ok, I've found it now. Check T509,510,511, and c517 electrolytic, for s/c. It should be one of those.
Bill
Old 15th Nov 2013, 4:46 pm   #13
ssjenkins
Thanks Bill . Will do . I probably won't be able to look at it till Tuesday , but I'll post back with my findings . Thanks again !
Sammy
Old 15th Nov 2013, 5:44 pm   #14
Not particularly helpful here but just for information- Hameg is now the Rohde & Schwarz presence at the budget end of the market. Disappointed to hear they're not interested in helping with earlier kit, though. If nothing else it's good "potential customer" relations.
Herald1360 is offline
Old 15th Nov 2013, 6:11 pm   #15
ssjenkins
Hi All .
Well I had a bit of spare time and I've found the guilty culprit . C519 was short . I've uploaded a photo . I know the value is 0.1uF , but can some kind person tell me what type it is . Is it a polyester ?
Thanks
Sammy
Old 15th Nov 2013, 6:16 pm   #16
Looks like it. M probably means 20% tolerance. Working voltage- you'll have to figure that by inspection of circuit......
Old 15th Nov 2013, 6:21 pm   #17
ssjenkins
Thanks . I think it's a 12V circuit .
Name:	Capture_003 15-Nov-13 18.20.jpg
Old 15th Nov 2013, 9:20 pm   #18
Yes- the cap is just HF decoupling for that 12v rail. Pretty much any radial lead polyester that will fit should do!
Old 15th Nov 2013, 9:33 pm   #19
PJL
That ones a ceramic and they are particularly good at decoupling. I am sure Maplins will have one (but that's probably not much help when you are in Spain!).
PJL is offline
Old 16th Nov 2013, 8:52 am   #20
ssjenkins
Originally Posted by PJL View Post
That ones a ceramic
Thanks for that PJL . I'll pick one up during the week when I get some time .
Cheers !
Sammy
