5th Jun 2023, 7:38 pm | #21 |
Re: A Softy 2 lives
In line with our usual policy of being unfailingly helpful, a sketch (attached) for a 74S287 PROM reader adaptor.
I did notice, though, that the 74S287 is soldered in. I have to admit I would be crippled by indecision, on the one hand not wanting to disturb pristine original 40+ year old solder, but on the other hand knowing that if that PROM ever fails and there's no independent backup of the code in it, the unit will be toast. I've been trying to work out what the PROM is used for, as it is very much part of the video generation circuit my guess would have to be that it is the character generator. |
5th Jun 2023, 8:17 pm | #22 |
Re: A Softy 2 lives
Yes I believe it is the character generator and I assume the marking is to show it is blown maybe?
I know that it was postulated in the previous thread that it was probably the same code as the Softy 1 as the circuit is essentially the same and it only can generate a very limited character set. I am am torn as if I fail to remove it then the read may be moot - I wonder if I can do it in circuit with the analyser clipped on top of it. |
5th Jun 2023, 8:20 pm | #23 |
Re: A Softy 2 lives
Thanks for the sketch by the way! I am glad we have a Softy2 to pick apart but, as you say very aware of the scarcity.
Imagine if I ever find a SCRUMPI 3... |
5th Jun 2023, 8:50 pm | #24 | |
Re: A Softy 2 lives
AnalogueMan may be quite bemused by all this talk of 'rescuing' the code from the programmed devices but ancient programmed devices are the bane of antique microprocessor based units like this because if they fail the unit is dead from that moment on unless the code to programme replacements with can be found somewhere - hence the need to read the code out of both of the programmed devices while they still work. |
5th Jun 2023, 8:58 pm | #25 |
Re: A Softy 2 lives
I wonder if you could connect a very fast Arduino to the A0-A7, Q0-Q3 lines and the 'G' line and have it capture the code coming out of the PROM for every possible value on A0-A7? Maybe that's something your analyser is clever enough to do.
5th Jun 2023, 9:22 pm | #26 |
Re: A Softy 2 lives
Hm the little one is only 8 channels + clock so would only have four address lines - not sure about the HP maybe.
5th Jun 2023, 11:09 pm | #27 |
Re: A Softy 2 lives
It might be possible to wire a battery backed ram onto the top of the prom, so every read from the prom is written to the ram. Then disconnect the battery backed ram and read the contents on a prom programmer.
6th Jun 2023, 12:43 am | #28 |
Re: A Softy 2 lives
Brilliant idea, I would never have thought of that. I think probably the best way to pick the signals up from the PROM without having to solder anything to anywhere would be to use an IC test clip, if Tim has such a thing.
Capture the whole 256 bytes like that, read it in an EPROM reader and then ask Chris to verify those 256 bytes against the SOFTY 1 character generator PROM code he has. The only problem I can forsee is, because this is a video generator circuit it may be running too fast for writes to the battery backed SRAM to succeed (PROMs were often used in this sort of application because they were much faster than other contemporary memory devices). Last edited by SiriusHardware; 6th Jun 2023 at 1:05 am. |
6th Jun 2023, 2:49 am | #29 |
Re: A Softy 2 lives
Looks like a 4MHz dot clock, with a 4 bit shift register. It might need fast access to read the data into the shift register at the correct time but hopefully the data is stable for a microsecond. Maybe the 4MHz clock can be used as write enable, but probably need to check it with a scope to see when data and address are stable.
6th Jun 2023, 8:20 am | #30 |
Re: A Softy 2 lives
If speed was an issue which prevented the available non-volatile RAM from capturing the output from the PROM you could slow the whole system right down temporarily by fitting a much lower frequency crystal, 1MHz or less, so that the 74S287 would be clocked / accessed more slowly. Of course it would not be possible to view the video output from the unit while running at 1/4 speed but the assumption would be that it would still be trying to render the contents of memory to the screen as hex characters, so hopefully every location in the character generator PROM would be 'exercised' anyway, slowly enough for the RAM to be able to catch it all.
6th Jun 2023, 9:26 am | #31 |
Re: A Softy 2 lives
Looking at the images Tim has posted so far it seems that the character generator only ever generates hexadecimal characters 0-9, A-F, is that right? I haven't seen other alphabetic characters in any images posted so far.
6th Jun 2023, 9:43 am | #32 |
Re: A Softy 2 lives
If it's anything like the oriignal Softy (which I have), then yes the character generator only displays 0-F.
A 'location' on the video display appears to contain 2 characters. The high 4 bits of the memory data are fed to the character generator, the output bits of that are serialised and sent to the video output. Then a mulitplexer switches over, the low 4 bits of the same memory data are sent to the character generator and the process repeated. |
6th Jun 2023, 9:55 am | #33 |
Re: A Softy 2 lives
Thanks for that - so it seems likely that the character generator would run through its whole character set within a very short time after power-on without any need for user intervention, which is what we would need in order to capture all possible address inputs vs. all resulting 4-bit data outputs.
6th Jun 2023, 10:00 am | #34 |
Re: A Softy 2 lives
FWIW the character generator n a Softy 1 is also a 74S287 and may well be the same programming. I can't remember if it's socketed n my Softy or not, but you could probably convince me to remove it and read it out.
6th Jun 2023, 10:40 am | #35 |
Re: A Softy 2 lives
Tim has speculated that the Softy1 / Softy2 char gen may contain one and the same code but Chris Oddy of these parts has already read the code from a Softy 1 char gen so I think yours can remain unmolested for the time being - thanks for the offer though.
Just looking at available options for physical devices to back the code up into, obviously a historically correct DM74S287N would be preferable but according to the PROM equivalence list on Mike's Arcade there are several pin compatible devices:- https://www.mikesarcade.com/cgi-bin/...ge=PromRef.txt 256x4 (Tristate) N82S129N (Philips / Signetics) AM27S21 (AMD) 6301 (MMI) DM74S287 (National Semiconductor), 24S10 (Ti) 7611 (Harris), 93427 (Fairchild?) Not mentioned specifically is the MH74S287 (Tesla) which presents the same difficulty to get programmed as its big brother the MH74S571. I have one or two NOS tubes of blank N82S129Ns since they were used for channel programming in Pye MX290 series radios which I had an interest in at one time. I'd be happy to donate a couple to a good cause once in posession of the correct code to program into them. |
6th Jun 2023, 8:37 pm | #36 |
Re: A Softy 2 lives
The SOFTY 1 character PROM dump can be found here: https://theoddys.com/acorn/proms_and...1/softy_1.html together with my Python emulator. I would be surprised if the SOFTY 2 is different as the character set is very simple ?
Chris |
6th Jun 2023, 11:58 pm | #37 |
Re: A Softy 2 lives
If it was me I would be supremely confident of removing the PROM to read it and refit it without leaving any trace due to a combination of decent desoldering equipment and decades of daily practice as a repair technician. I have to appreciate that it's not such a routine process for most other people, and this would be a fairly high-stakes operation which must not be messed up.
Given the apparently high likelihood that the character PROM is actually the same as the one in the Softy 1, I think if I were Tim I would ride my luck and deal with PROM failure if it ever happens. We could resolve this another way - Tim gives you all the info you need to make a working Softy 2 replica and you then put a Softy 1 PROM in it and see if it works. If it does, that will answer the question without inflicting any unnecessary disturbance to the historically original fabric of Tim's Softy 2. If it doesn't work, we will be back to needing to see the actual code from a Softy 2 PROM. |
7th Jun 2023, 11:58 am | #38 |
Re: A Softy 2 lives
I am reasonably confident with desoldering and have the tools to achieve it so I may pull the PROM as the simplest way to do this especially if Sirius can program a substitute. I will examine if there is room for a socket in which case we could also prove the the substitute worked...
Anyway here is a closeup of the chars 0-F as a sequence in the front of RAM buffer. On a more prosaic note I think I need other repairs anyway. I got hold of a BNC cable so now have a slightly better way to view the screen - although I still lose a small portion of the bottom line and the digital scan controls on this monitor seem to crash out when I try them (arghhh). Anyway if you look carefully you can see some corruption of the display towards page 2 of RAM buffer (the grey background graduations are used to judge them). I filled the boundary areas with repeating 0123456789ABCDEF so you can see the effect better. This video shows that this is quite catastrophic as the 'cursor' jumps around the columns as it comes up one line at a time so there is a frame shift happening as well at this point which perseveres all the way down, https://youtube.com/shorts/FHxVTTVNRJU?feature=share I filled the boundary areas with repeating 0123456789ABCDEF so you can see the effect better. Do not be confused by the first and last few columns they I believe are artefacts of the video generation that would normally be in the overscan area which are duplicates of the main data - this leads to a duplicate cursor anyway - hopefully Chris can confirm he can see that effect - it is clear here in the upper part of the buffer where the cursor triggers twice perhaps... Last edited by Timbucus; 7th Jun 2023 at 12:05 pm. Reason: Make clearer |
7th Jun 2023, 1:46 pm | #39 |
Re: A Softy 2 lives
As a double check, do you also see that corruption via the modulator / RF connected TV?
If the monitor you are currently using is specifically meant for CCTV use, does it have a 75R termination with an on / off switch next to the BNC input? What happens if you move it to the position it isn't in now? If you do consider putting the PROM in a socket which will obviously raise it up higher off the PCB, remember how @~! hot those things get - if you put it too close to the 'lid' it could end up heat-browning the enclosure. |
7th Jun 2023, 1:57 pm | #40 |
Re: A Softy 2 lives
In your picture in post #15 shot from the CRT TV screen the characters throughout the second pale band down look perfectly OK.
I'm not sure if what you are getting on the flatscreen isn't just the result of the flatscreen monitor trying and failing to put what it may see as a highly unorthodox video signal on the screen as best it can. |
