Old 11th Jan 2019, 5:05 pm   #21
avocollector
Default Re: ESR Meters.
My thanks to both David and Mark for their posts - most enlightening.
avocollector is offline
Old 12th Jan 2019, 12:47 am   #22
Tim
Tim's Avatar
Given the prices of them in the above thread, I'm even keener to build one! I have all the bits and instructions/ circuit. Now all I need is the time!
Tim is offline
Old 12th Jan 2019, 4:03 am   #23
evingar
evingar's Avatar
Originally Posted by Argus25 View Post
The best ESR meter I have ever used was the one designed by Bob Parker. I have the kitset version of it made by Silicon Chip, available from Altronics with a lovely black housing and Red LED's, but they come in other forms:
Another vote for the Bob Parker design here
I have 2 meters, both built from kits, an older Anatec "blue" and one from a chap in Portugal (EVB).
http://clientes.netvisao.pt/greenpal/evb1.htm
Both versions seem very well protected from applied voltage, judging from the daft things I've done to both. It's nice to have a circuit diagram for both. The only thing that isn't an off the shelf part is the programmed uP.
Chris
evingar is offline
Old 12th Jan 2019, 4:08 pm   #24
jimmc101
jimmc101's Avatar
A varied collection of homebrew ESR meter circuits is available on kripton2035's site
Jim
jimmc101 is online now
Old 12th Jan 2019, 4:28 pm   #25
Philips210
Hi.
I built a very useful ESR meter from TELEVISION magazine. The project was by Alan Willcox and the articles can be found here https://www.vintage-radio.net/forum/...ad.php?t=93523 post#5 thanks to member KeithsTV.
Regards
Symon.
Philips210 is offline
Old 13th Jan 2019, 9:20 pm   #26
M3VUV51
look at my homebrew one from p diddy at eev blogg,also the chinese esr meters use a too high voltage to test in circuithttps://www.eevblog.com/forum/projects/5-transistor-esr-meter-design/200/
M3VUV51 is offline
Old 13th Jan 2019, 10:12 pm   #27
Bazz4CQJ
Bazz4CQJ's Avatar
Are you saying that someone has tested all of the "chinese esr meters" and established that they all work on too high a voltage to use 'In-circuit', or is that just a sweeping generalisation? The point has to be stressed here that if you buy a tester for the lowest price on the market, you would be foolish to think it is likely to perform as well as something costing appreciably more.
I think that the issue of testing the ESR of capacitors 'in circuit' is regarded by some people as a bit of a grey area, and there is some possibility of getting a false reading even when low voltage tester is being used.
B
Bazz4CQJ is offline
Old 13th Jan 2019, 10:30 pm   #28
evingar
evingar's Avatar
I think you have to use your head a bit and work out what's in parallel. Measuring caps in circuit has saved me a lot of time when repairing SMPSU's.
Chris
evingar is offline
Old 4th May 2019, 8:18 am   #29
Longespee
After reading this thread and finding it most useful and interesting ( apart from the fact I'm borrowing an ESR more often than I feel comfortable with ) , I have opted for the Peak, should be here next week.
Longespee is offline
Old 4th May 2019, 9:43 am   #30
HamishBoxer
HamishBoxer's Avatar
You will not go wrong with the Peak.
HamishBoxer is offline
Old 4th May 2019, 3:00 pm   #31
Pamphonica
Pamphonica's Avatar
The "Eureka Moment" for me was over 12+ years ago when I was trying to faultfind a switchmode power supply on a Philips scope which was giving a very fizzy trace. I HATE switchmodes!
Michael Maurice offered to let me come over and he would show me what an ESR meter can do. A few minutes of in-circuit ESR testing and the faulty caps were clearly identified.
There were so many that he suggested a complete re-cap, which I did, and the scope sprang back to life.
Since then I have always used an ESR meter on electrolytic caps involved in power-related faults.
And yes, I decided to treat myself to a Peak Electronics one. I damaged one test lead (cut through in error), and Peak volunteered to send me a new lead set foc. Now that's service!
Jeremy, G8MLK, BVWTVM Friend, VMARS, BVWS Secretary.
www.pamphonic.co.uk www.bttt.org.uk
Pamphonica is offline
