Old 11th Dec 2018, 9:42 pm   #1
Breton56
Default Grundig TK5 motor not running
I have aGrundig TK5 which has been in the family since around 1960.my brother having bought it second hand.I have had it in store in my cellar for the last five years-the cellar is damp so when I unearthed the machine recently,I found the motor would not run and feared that the motor windings may have failed.I do not have any service info for the recorder(I have not look inside it since the 60's) but on operating the motor switch I discovered that the lower toggle switch,operated by a cam on the switch shaft was not toggling.On closer inspection I could see that the metal toggle on the switch had become loose in the switch assy.Has anyone come across this problem before and found a cure for it?
PS.
Forgot to say, when I shorted the switch tags, the motor ran.
Breton56 is online now
Old 11th Dec 2018, 10:25 pm   #2
camtechman
camtechman's Avatar
Default Re: Grundig TK5 motor not running
Grundig seemed to use more switches than other machines.
C
One that suffers from switch problems that I came across (as I'm a collector of) was the Grundig C100 & C100L models. These were not R2R machines but early cassette machines. and instead of encapsulated types they used skeleton (open frame) switches, an open version of an encapsulated micro switch, which exposed the actuating bronze, flattened spring. This was from the same decade as you're TK5
This spring, due to a moist environment would hesitate or even fly out.
Worst was, this switch had to be removed before servicing the machine and, if this was not done prior to disassembly, could disappear inside the inner mechanism, or fly out never to be found again.
Your switch doesn't seem to be that type but it may be removable and serviceable/repaired.
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it!
camtechman is offline
Old 24th Dec 2018, 10:25 am   #3
jonnybear
jonnybear's Avatar
Pm sent.
John
jonnybear is offline
