Old 23rd Aug 2019, 10:00 am   #1
G0HFCFrank
Default Roberts RMB Wavechange
Hi Folks,
The previous opponent of this Roberts RMB removed all the wires from the wave change switch and created the rats nest pictured. Looking at the circuit, the MW aerial coil L1 is the frame aerial and has four wires, black red yellow and green. I assume these correspond to connectors a b c & f on the diagram. The black wire is connected to chassis, yellow to C34 (tuning cap) and red and green jointed together and connected to the MW aerial trimmer C32.
I intend to repair or replace the 4 pole 3 way waveband switch and rewire back to original. Trouble is I don't know where the red green and yellow wires should go as I don't know which is which. If some kind soul with the same receiver could identify them for me I would be most grateful.
Frank C.
ID:	188762   Click image for larger version
ID:	188763   Click image for larger version
G0HFCFrank is offline
Old 23rd Aug 2019, 3:24 pm   #2
GeoffK
Default Re: Roberts RMB Wavechange
The red arrows show the 4 poles of each three way switch bank.
With switch in position S1 this is for MW section.
(Bank 1 aerial pole) S1 switched to L1 (MW frame aerial) inner, S4 (bank 2 pole from C4 aerial tuner & C5) to other (outer) side L1 top & trimmer C1.
S7 (bank 3) (from C8 & C9 osc tuner) to S7 (L9 osc pri) S10 (bank 4) (L12 osc sec & second grid (osc anode) V1
Repeat for other two switch positions.
Black would be going to common of trimmers C1 C2 C3 and C13 C14 C15 (C12) in osc section.
Geoff
GeoffK is offline
Old 23rd Aug 2019, 5:46 pm   #3
ms660
ms660's Avatar
So far as I can make out....
Red (d) connects to S1, 2 & 3's wiper.
Green (b) connects to S2.
Yellow (a) connects to S5.
Black (c) connects to chassis.
Based on the Trader sheet schematic and switch drawing and a photo in the GVR forums gallery.
Lawrence.
ms660 is offline
Old 24th Aug 2019, 9:04 pm   #4
G0HFCFrank
Thanks Guys,
Geoff your pic of the front end is different from Trader Sheet 1037 and easier to read; Lawrence, thanks for the colour identification, it makes things a lot easier. Not much spare time this next week but watch this space!
Frank.
