Old 5th May 2019, 10:41 pm   #21
Akashamitra
Default Re: Tape Speed Control Stuck on UHER 4000 Report IC.
Itís the 4000 report IC. Thanks for the tip on getting at the speed adjuster. Itís definitely screwed in somehow. Itís removable but very awkward to get at. I donít have a screwdriver suitable at the moment but reckon itís do-able if I can find one. Have attached a photo I think but Iím doing this on my phone. Thanks for all your help!
Akashamitra is offline
Old 6th May 2019, 5:08 pm   #22
barretter
It looks like you just need a normal reasonably long screwdriver to undo the screw which is attached to the front panel and then remove the tag which is holding the speed-change shaft down. You then need to reattach the dangling spring to the hook which projects from the hinge of the circuit board.
If you need to undo the screw at the other end of the speed-change lever be very careful as it is holding down a spring. You would also need to undo the two screws holding the motor in place and move it aside.
ID:	182571   Click image for larger version
barretter is offline
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright ©2002 - 2020, Paul Stenning.
