Old 25th Aug 2019, 9:03 pm   #1
kestrelmusic
kestrelmusic's Avatar
Default Horrible hum on Marconiphone radiogram
I've nearly finished restoring a nice Marconiphone model 286 radiogram (it's the same as the HMV Model 444). The radio works a treat but I am getting horrible 50 c/s hum on the Gram setting. The original pickup coil was o/c so I rewound it with as much 42SWG as I could get onto the bobbin. The hum is only there when the motor is running, so I can only assume that the pickup coil is getting some magnetic pickup from the motor windings. There's no hum on MW or LW when the motor is running.
I also have a Columbia Model 228 record deck which suffers from the same problem; it seems to be electrically and mechanically identical to the HMV/Marconi apparatus.
Is there any way of screening the pickup coil from external magnetic fields? Alternatively, has anyone ever tried fitting a crystal cartridge into the Bakelite headshell? I'm sure one would not take the weight of a Bakelite arm and a steel needle, but might there be some way of coupling one indirectly?
kestrelmusic is offline
Old 25th Aug 2019, 9:44 pm   #2
Heatercathodeshort
Heatercathodeshort's Avatar
Default Re: Horrible hum on Marconiphone radiogram
Interesting. Something tells me this pick up should have a 'hum bucking' coil. This has the appearance of the pick up coil and is usually mounted just above the assembly and is wired in anti phase. You may have disturbed/miss wired it? Just a thought. John.
Heatercathodeshort is online now
