Old 31st Aug 2019, 11:37 am   #1
Bigmike1958
Default Sony KV-1330 tv
I’ve got Sony trinitron tv late 60s kv 1330 can anyone help me with problem if you touch and control colour sound etc goes to b& w brightens flicker as dose contrast and sound controls don’t respond correctly is it a loose connection or clean contacts thank hope you can help
Bigmike1958 is offline
Old 31st Aug 2019, 9:45 pm   #2
gec2110
Default Re: Sony KV-1330 tv
The first thing would be to clean all the controls not the tuner with switch cleaner.
If you are not familiar with these sets best left to expert
they are quite complex
Also could deliver quite a nasty shock if you are not use to servicing
Mark.
gec2110 is offline
Old 1st Sep 2019, 7:46 pm   #3
simpsons
I agree with GEC2110, the trick, having unplugged the set, is to remove the outer wooden case from the chassis. This will give you access to the controls.
The thing is, it isn't just a matter of unscrewing specific screws on the plastic back. There are 2 underneath as well.
As far as I remember, the SONY KV1320 Mk2 is the same as the KV1330. If so, Google SONY KV-1320 MK11, you will see the Vrat heading. Open the topic. Click on the photo of the TV and you will see the insides of your set, the back and fixing screws.
As GEC2110 said, should you be unfamiliar with servicing do seek a local BVWS member's help. These Sony's are very good but need TLC when handling as there are lots of soldered wires which can break off easily with few plugs and sockets when removing parts or panels for servicing.
Chris
simpsons is offline
