9th Sep 2018, 3:45 pm | #1 |
Dynatron GR14 Cordova stereo problem.
Hope someone can help. I've got a Dynatron Cordova mono record player in really nice condition. However, when playing stereo records one channel is barely audible. I know this deck originally came with an optional extra speaker for stereo sound so I tried plugging in additional speaker but still you can barely hear one of the channels.
Could this be just a stylus issue, or something more serious? Thanks |
9th Sep 2018, 5:45 pm | #2 |
Re: Dynatron GR14 Cordova stereo problem.
There's no point in plugging a speaker into the "stereo" socket on your Dynatron. You'll not get stereo, in fact you won't hear anything. This socket is for connecting a stereo adaptor unit (i.e. a amplified loudspeaker) for the RH channel. We need to know what kind of cartridge is fitted to your tone arm. It may be a stereo-compatible mono cartridge (2 connectors) in which case you will automatically hear both channels - or - it may be a stereo cartridge (4 connectors) which will need the LH and RH channels bridging. Please advise.
Edward. |
10th Sep 2018, 8:38 am | #3 |
These usually came with a Garrard 3000 series deck and a Sonotone 9TAHC or Acos cart, both of which are stereo. If you're missing one channel, check first the connections at the cart rear - be very careful as the wires are very thin and can easily detach from the soldered tags if handled at all roughly.
I do not know if these units have a make/break socket/plug contact for bridging the two channels to mono when not used with extension stereo amp/speaker (a la Bush SRP31) - that would be the next area to check. Perhaps someone here more clued in could advise on this point.
Regards, Ben. |
10th Sep 2018, 9:25 am | #4 |
10th Sep 2018, 8:00 pm | #5 | |
Actually the 2nd speaker just reproduces the sound from the main speaker - ie very quiet LH channel. |
11th Sep 2018, 8:58 am | #6 |
You've attached a picture of the stylus not the cartridge. The 'S' does indeed stand for Stereo. This simply means that the stylus tip is of a radius suitable for playing stereo records. The cartridge is the item into which the stylus clips, and will have a make/model no. similar to those suggested by Ben in post # 2, although it could be another make and model.
11th Sep 2018, 9:02 am | #7 |
That looks like a BSR ST12/14/15 to me, though I've not seen one with the lettering embossed before. As suggested by LIVEWIRE, a picture of the cartridge in the arm would help. I suspect someone has replaced it at some point in time and not connected it up correctly.
Regards, Ben. |
13th Sep 2018, 7:25 pm | #8 | |
The cartridge has 4 wires connected, all seem to be firmly soldered and connected properly. Perhaps I need to remove the deck and investigate the other end as suggested by Ben? |
13th Sep 2018, 11:18 pm | #9 |
That's a Sonotone 52T. Very scarce outside the US. It may well be knackered like quite a few of this era now are.
One quick test before condemning it. Put the volume about midway. Get a small jewellers metal screwdriver and , with the arm raised as in your first photo, gently touch each of the 4 contacts. On two there should be a loud ish buzz. Post back with findings.
Regards, Ben. |
14th Sep 2018, 4:52 pm | #10 |
Thanks Ben, I tried that and yes indeed, two of the wires buzz (the green and white if that makes any difference).
15th Sep 2018, 9:08 am | #11 |
Just a thought, you may be able to fix the Cartridge, could I suggest you take a look at some pictures on the thread “bass response....”. I opened a Sonotone cartridge and found corrosion on the pins, the ceramic elements were ok. It’s a bit tricky but if all fails at least you had a go.
Cheers John |
