Old 9th Sep 2018, 7:36 pm   #21
Junk Box Nick
Junk Box Nick's Avatar
Default Re: Prepare to man the barricades
Ummm. Bought an answerphone (actually a phone handset with this facility) last month. I guess I'm behind the times but then I am into vintage technology...
Junk Box Nick is offline
Old 9th Sep 2018, 8:42 pm   #22
HamishBoxer
HamishBoxer's Avatar
Not at all,I have a ## call blocker with answer phone and I must say a great bit of kit.Bought in the last 2 years I add.New that is.
Also I have a much older answer phone that dials the callers number and tells you who called.(1571)
HamishBoxer is offline
Old 10th Sep 2018, 12:01 am   #23
emeritus
As I mentioned on another thread today, Toolstation are presently offering a large range of Corby-branded halogen GLS bulbs for under £1 each.
emeritus is offline
Old 10th Sep 2018, 12:53 am   #24
julie_m
I've always wondered about the effectiveness of those ceiling hung electric fires that point downwards from a height of several yards in factories and the like. I'm imagine most of the heat just went upwards!
Those heaters use mainly radiant heat, i.e. infra-red; which travels in straight lines until it is reflected, refracted or absorbed; and is only converted into heat where it is absorbed by something (or someone).
I suppose you could call it matter-heating as opposed to space-heating. When used in conjunction with motion detectors, they can be very efficient, heating literally only the people in a room.
julie_m is offline
Old 10th Sep 2018, 7:31 am   #25
Damien VK3RX
Damien VK3RX's Avatar
Halogen bulbs? Still a few available here, so best stock up also.
Thus far I've only found one brand of LED bulb in the conventional shape that don't cause RF interference somewhere in the spectrum.
Fax machines; still use one occasionally for documents containing personal details such as CC numbers (and it works fine via a phone port over our new VDSL network). Seems safer sending this stuff via fax machine to fax machine rather than scan and send via email.
New landline telephone has an inbuilt answering machine.
Cassette tape/player: just picked up a Sony TCM5000EV to play old radio recordings around here - without using the rarely used tape deck in the HiFi system.
Pagers? Heavily used by some branches of the emergency services here.
Not sure where the good Prof got all her info from
Damien
http://www.vk3rx.com/
Damien VK3RX is offline
