11th Mar 2006, 10:25 pm | #1 |
DIY tuning dials
I've just finished making a replacement dial for my Armstrong tuner amp . The original , broken, dial was scanned and repaired using photo editing software. Tuning dials, mostly, need to be both opaque and transparent in different areas. An inkjet printer will print on transparency film, but the inks will be transparent and printing on paper will produce an opaque image. My solution was to use both mediums and cut the transparent areas from the paper version with a scalpel. The transparency is then carefully aligned and stuck over the paper using a very thin line of pritt stick, just, around the edges. Then, simply, sandwich it between two pieces of glass (I cut the glass from a 40 X 50cm picture frame from a 99p shop ). Anyhow, I've attached three pictures, the first is the paper copy, the transparency and then the finished article Hope this will act as encouragement and inspiration to anyone who is unfortunate enough to faced with a broken dial David |
12th Mar 2006, 12:02 am | #2 |
Re: DIY tuning dials
Well done Dave. A great piece of work, it really looks the part.
You must have the patience of a saint! rgds Colin |
12th Mar 2006, 11:04 am | #3 |
That looks perfect, David - well done. I fear that forum members will be beating a path to your door.......
Mike. |
12th Mar 2006, 4:16 pm | #4 |
Very nice job David.
Does anybody have any suggestions as to how to print white lettering on a transparent background? Best regards, Paul |
12th Mar 2006, 5:44 pm | #5 | |
Paul et al
Have a look at www.craftycomputerpaper.co.uk and go to "Decal papers & transfers". Then go down to "embossing powders for lettering". I bookmarked this page from another thread but I'm afraid I've no idea who posted it. Anyway, it sounds interesting & for £1.99 it isn't much to gamble. Personally I haven't tried it, but probably will in time. Quote:
Joe |
12th Mar 2006, 5:48 pm | #6 | |
Thanks for all the nice comments
There are ways around it though, I am at this moment trying to repair the dial for my Pye Fenman II. The middle waveband (white) lettering was flaking badly, so I washed it away completely . Hopefully I will, soon, print that section onto transparency film but with the colour of the letters changed to black . If I'm not happy with that outcome I'll print the whole dial (with the correct coloured writing) onto matt photographic paper with a dark blue background and place it behind the tuning indicator with a piece of plain glass in the front ... Ok neither will look totally original but it's the best I can think of David |
12th Mar 2006, 6:02 pm | #7 | |
