25th Feb 2006, 6:53 pm | #1 |
Foam Cleaner
Just in case anyone is as stupid as me and doesn't bother to read instructions, don't spray foam cleaner (certainly not the CPC stuff, anyway) onto switches. I thought I'd clean my remote plipper for the car, so pulled it apart and liberally sprayed it with the cleaner. I let it dry out, put it back together and it seemed to work OK.
Later on, came to use the car again and it wouldn't unlock. After some messing I discovered that 2 of the 3 switches in the unit were measuring circa 2K when open. Fortunately removing the switches and soaking them in isopropyl alcohol seems to have returned them to normal. It does warn about spraying directly onto electrical equipment but I'd assumed it just meant it was flammable, not that it was conductive. |
25th Feb 2006, 6:59 pm | #2 |
Re: Foam Cleaner
It's possible to knacker computer keyboards by an overenthusiastic application of foam cleaner. Thanks for the reminder Steve.
Paul |
25th Feb 2006, 7:07 pm | #3 |
Re: Foam Cleaner
And if you spray it on paxoline with screen printed writing like aerial/earth gram tag strips, the writing will come straight off. Guess who found out the hard way!
26th Feb 2006, 11:20 am | #4 |
Re: Foam Cleaner
There are many different types of foam cleaner on the market. Maplin's own brand is quite corrosive and more useful for cleaning greasy hard surfaces. There is even a warning on the tin that it can etch glass and all residues need to be removed. Certainly not one for radio dials or computer keyboards. The Servisol brand is more gentle. It is good for CRT screens , plastic cabinets etc and also contains an antistatic agent.
26th Feb 2006, 2:51 pm | #5 |
Re: Foam Cleaner
Yes, I'd recommend the Servisol one as about the best around - you get what you pay for!
I tend to be rather more cautious these days, having disintegrated all sorts of things with liberal application of solvents. Hey Ho, we live and learn!
Brian |
26th Feb 2006, 3:08 pm | #6 |
Re: Foam Cleaner
I've found Aldi Power Force Bathroom Cleaner works well without any nasty surprises, so I stick with that (99p). Anything designed for cleaning cooker tops is likely to be caustic, and anything that mentions limescale is likely to be acidic.
Best regards, Paul |
26th Feb 2006, 10:35 pm | #7 | |
Administrator
Re: Foam Cleaner
26th Feb 2006, 10:54 pm | #8 |
Re: Foam Cleaner
I have always used "simoniz foaming upholstery cleaner" - superb stuff and as far as I can see not corrosive.....
Volkswagen used to do their own version, and it would shift everything and lasted for ages, but it never caught on at 22 quid for a tin! Cheers Sean
6th Mar 2006, 7:29 pm | #9 |
Re: Foam Cleaner
I have found that Electrolube CTC "Carterclene" is the best of the bunch. It works well, even on Inkjet Ink, and does not seem to harm anything I have tried cleaning with it.
It does a great job on Bush VHF64 Piano Keys and Knobs and is good on glass. It's water based, so never use it near switches of any sort. I believe its active ingredient is ammonia. As an aside, it is fantastic for alloy wheel cleaning and removing old, nasty grease from cooker hoods and tiles. I love the stuff.. Jim |
7th Mar 2006, 11:11 am | #10 |
Re: Foam Cleaner
I also find Carterclene fairly effective, we use it as standard here at work. I had a nasty surprise one day though after I had just repaired an instrument. I decided to give the front panel a quick clean up with Carterclene and I suddenly noticed the screen print floating away with the run-off , it seemed to have just lifted it .
Neil |
