Old 13th Feb 2019, 12:12 am   #1
Default AVO 8 (MK1) with red and black binding posts
There is an Avo model 8 (mk1), with red and black banana terminal built in Dover.
As far as i know, the factory in Dover opened in April 1964.
The Avo 8 mk2 was introduced in 1956, so for several years it seems that Avo was producing both models, 8 mk1 but using the new black and red banana jacks and the model 8 mk2.
Name:	Captura de pantalla 2019-02-12 a las 22.52.37.jpg
Old 13th Feb 2019, 12:49 am   #2
Sinewave
Sinewave's Avatar
Default Re: AVO 8 (MK1) with red and black binding posts
I've never seen a mark 1 with the newer terminals. That on the left is a mark 2.
Avometer, vintage Fluke and Marconi collector. Also interested in vintage Yaesu and KW.
Sinewave is offline
Old 13th Feb 2019, 1:03 am   #3
The one on the left has a blank space instead of 500 volts. And the scale of both are the Avo 8 mk1 one. In this photo it can see better.
If it is a model 8 mk1 with new terminals, i think it is strange due to the dates of the opening of the Dover Factory.
If it is a a model 8 mk2, it has the front panel of the 8 mk1 without the 500 volts range. That seems even more strange for me.
Name:	Captura de pantalla 2019-02-13 a las 0.07.13.jpg
Old 13th Feb 2019, 6:42 am   #4
Sinewave
Sinewave's Avatar
The early mark 2 didn't have the 500vdc range.
Sinewave is offline
Old 13th Feb 2019, 8:23 am   #5
Ok I see. And also have the scale of the mk1 as I can see
Thanks
Old 13th Feb 2019, 8:43 am   #6
Sinewave
Sinewave's Avatar
Mk 1 to 3 had the same scale. Scale changed for Mk 4 and again from mk 5.
Sinewave is offline
Old 13th Feb 2019, 9:08 am   #7
I though Avo 3 did not have “thousands” at the top (left side)but is just the number and letter style what is different.
Thanks
