Old 10th Feb 2019, 4:38 pm   #1
Julesomega
Julesomega's Avatar
Default DMMs with pushbutton range selection
I have a basic 3½ digit DMM which I brought home about 1995 when it had been damaged, a Kikusui 1506. It runs on a PP3 or external supply and my guess is that it had been bought in the 80s. I noticed that the Fluke 8060A looks very similar when one appeared on eBay in 2017 (I didn't buy it). Since then I have noticed a similar-looking meter in the background of the images of one or two other members here. Maybe they were sold through RS or Farnell.
I am wondering if this presentation style was picked up by any other DMM makers of the period. Also I would be very grateful for any servicing info as I could then calibrate mine, in particular by zeroing the display. I note that the one on eBay was showing a similar offset!
Name:	Kikusui 1506 front.JPG
ID:	178146   Click image for larger version
Name:	Fluke 8060A front.jpg
ID:	178147   Click image for larger version
Name:	Kikusui 1506 rear.JPG
ID:	178148   Click image for larger version
Name:	Fluke 8060A rear.jpg
- Julian
It's good here
Julesomega is offline
Old 10th Feb 2019, 4:59 pm   #2
Julesomega
Julesomega's Avatar
Default Re: DMMs with pushbutton range selection
In answer to my own question, I found a 1990 RS catalogue which has 6 Fluke meters in this style: 8020B, 8021B, 8024B, 8026B, 8060A, 8062A. The Farnell cat from that time shows just the 8060A. This seems to date the Kikusui from either side of 1990
- Julian
It's good here
Old 10th Feb 2019, 5:12 pm   #3
barrymagrec
I`m not sure of the model numbers but that style of Fluke meter goes back at least to 1980.
barrymagrec is offline
Old 10th Feb 2019, 5:19 pm   #4
Sinewave
Sinewave's Avatar
I love those old Flukes, have a few here. My father did have one at some point too, not sure if he still has one.
Avometer, vintage Fluke and Marconi collector. Also interested in vintage Yaesu and KW.
Sinewave is offline
Old 10th Feb 2019, 7:13 pm   #5
Radio Wrangler
Radio Wrangler's Avatar
I have a Fluke 8060 and it is an excellent meter. True RMS, no annoying autoranging and plenty of counts.
The switching is clever, if a bit fiddly to use, and it looks like Kikusui copied this.
Radio Wrangler is offline
Old 10th Feb 2019, 7:16 pm   #6
Nickthedentist
Nickthedentist's Avatar
Yes, many cheap (Korean?) meters copied this layout, including some in Maplin's "Precison Gold" range. I have one bought for me by my dad for my 12th birthday in 1985. It still works to this day.
It was still shown in the 1995 catalogue so presumably it was a successful design
https://www.picclickimg.com/d/l400/p...Gold-M6000.jpg
N.
Nickthedentist is offline
Old 11th Feb 2019, 7:06 pm   #7
buggies
buggies's Avatar
My most used DMM is a Weston 6100. This was issued to Solartron field service engineers as it was produced by a sister company and was a bit handier than their own small bench models. Think it came out about 1980 according to the advert.
George
buggies is offline
Old 11th Feb 2019, 7:12 pm   #8
MrBungle
MrBungle's Avatar
Altai made one that looked like one of them. We had them at university.
MrBungle is offline
Old 12th Feb 2019, 10:24 pm   #9
Andrewausfa
Andrewausfa's Avatar
Hioki did a side switch DMM with a calculator on the front. Also the Heathkit IM-2215.
Andrew
Invisible airwaves crackle with life. Or they should do.
BVWS Member
Andrewausfa is offline
Old 12th Feb 2019, 10:27 pm   #10
Andrewausfa
Julian,
Servicing for your Kikusui
https://www.kikusui.co.jp/kiku_manua...IC/1506_JE.pdf
Andrew
BVWS Member
Old 13th Feb 2019, 1:03 am   #11
Julesomega
Julesomega's Avatar
The Weston 6100 looks like it's halfway between the Fluke and the Kikusui, and I love the 5-range bleeper system. I found a 1990 Maplin catalogue which shows their ownbrand M6000, and they also had a capacitance meter and a temperature meter with the side pushbuttons.
Thanks so much to Andrew for finding the 1506 manual (in Japanese and English)
- Julian
It's good here
Old 13th Feb 2019, 1:42 pm   #12
Jonster
I picked up a Fluke 8020A at a radio rally a while back for a couple of quid, it still works well.
Jonster is offline
Old 13th Feb 2019, 4:37 pm   #13
Nickthedentist
I can beat that! Mine cost £1 in the local charity shop in January, complete with case and probes. I wasn't expecting it to work, but was delighted to find that it had been stored with the battery removed, and when I replaced it, it worked perfectly, and agreed with my new Fluke (on the DC volts range anyway).
Old 18th Feb 2019, 12:25 am   #14
Techman
Techman's Avatar
Seeing this thread has reminded me that I have a version of this meter that I'd completely forgotten about and has been in a cupboard for a number of years. Luckily it still works perfectly (although I haven't tried all ranges) and the battery that I left in it still seems good. It's a Bewa DMM 6010 GS and unfortunately it's missing a push button cover and the 'stand-up' bracket is partially broken. I don't know what those test leads are from, possibly Heathkit?
Picture of it below:-
Techman is offline
Old 18th Feb 2019, 1:51 pm   #15
BulgingCap
Techman- That is a coincidence. I was using one identical to that today except it was grey. I didn't look what the brand was. I was helping a non-electronic friend (actually an ATPL and good mechanical engineer) with a problem with a Li-ion pack and he produced this meter. I was immediately reminded of the Fluke 8060 that I was issued when I first started work because it is easy to catch the buttons and change ranges when picking up the meter to move it.
BC
BulgingCap is offline
Old 18th Feb 2019, 4:39 pm   #16
ex 2 Base
I have an identical meter to what Techman has. I've had mine almost 40 years and its still going strong, bought via an advert in ETI magazine and the first purchase I made with a credit card. I've never bothered to compare readings with any other meter.
ex 2 Base is offline
Old 4th Apr 2019, 12:49 am   #17
Julesomega
Julesomega's Avatar
The manual allowed successful calibration of the Kikusui 1506. VR-1 sets 2V ac, VR-3 sets 2V dc, and VR-5 sets 200mV dc.
Shorting the inputs, I found that VR-6 sets zero reading. No procedure is given for adjusting the resistance ranges, but it reads in agreement with a Solartron 4½ digit instrument. No procedure is given for VR-2 and VR-4 so having tried for any effect I left them roughly as they were. I plan to use this a lot.
Name:	Kikusui 1506 adj.JPG
- Julian
It's good here
