Old 5th Feb 2019, 4:34 pm   #1
G4YVM David
G4YVM David's Avatar
Default KW 108 monitor scope woes
Not me this time, but a friend (honest). He has a KW 108 monitor scope which is giving him grief. About a minute after switch on it causes the RCB in the house to trip. Every time it's the same. He opened it expecting to find a capacitor issue (he is ex electronics engineer, clever stuff as well as tellies etc) but he can't find any tell tales for that at all. Now he is suspicious of the transformer and is asking about how to test this. I suggested the resistance in the windings but as he has no manuals or service data, he's a bit stuck.
I suggested lifting all the secondaries and putting them back one at a time to see which, if any, causes the circuit breaker to trip.
Anyone offer any thoughts??
David, G4YVM.
G4YVM David is offline
Old 5th Feb 2019, 4:41 pm   #2
Station X
Station X's Avatar
Default Re: KW 108 monitor scope woes
RCCB or RCBO?
Graham. Forum Moderator
Station X is online now
Old 5th Feb 2019, 7:03 pm   #3
G4YVM David
How do I tell them apart?
David, G4YVM.
Old 5th Feb 2019, 7:16 pm   #4
Station X
Station X's Avatar
I don't think there is such a thing as an RCB. RCCB's (Residual Current Circuit Breaker) sense imbalance in the currents flowing the live and neutral leads. RCBO's are similar, but also incorporate overload protection in a similar manner to an MCB (Miniature Circuit Breaker).
If the device is an RCBO then tripping could be caused by an overload rather than an earth fault.
Old 5th Feb 2019, 7:44 pm   #5
G6Tanuki
G6Tanuki's Avatar
What's the supply/earthing scheme involved? (I'm only really familiar with "TT" since that's what I've had in my houses/outbuildings for the last 30-odd years).
If the problem was shorted turns somewhere within the transformer I would expect it to blow the unit's fuse or the plug-fuse (or at least get very hot and smelly!).
My initial opinion is that the issue is a primary-side live-to-ground fault-current - either in the transformer (insulation breakdown/primary-to-ground short) or because a primary-side suppression-capacitor/mains-filter to ground is failing. Even shorting neutral to ground will cause a trip on a "TT" scheme.
G6Tanuki is offline
Old 5th Feb 2019, 8:34 pm   #6
G4YVM David
The puzzle is that it lasts a minute before blowing
David, G4YVM.
Old 5th Feb 2019, 9:13 pm   #7
Station X
Station X's Avatar
Has a simple Megger insulation test been done on the transformer?
Old 6th Feb 2019, 12:23 pm   #8
G8BBZ
G8BBZ's Avatar
Hi All,
The manual for the KW108 is available on the KWRadios forum on groups.io
A quick look shows that there are no capacitors fitted on the primary side of the mains transformer, so unless these have been added this would not seem to be a possible cause. The one minute delay to the fault occurring sounds like something heating up and then failing. If it's not the transformer itself my favourite would be one of the electrolytics on the EHT secondary.
cheers
Peter G8BBZ
G8BBZ is offline
Old 6th Feb 2019, 12:51 pm   #9
G4YVM David
Thanks Peter. I'll have a look.
David, G4YVM.
Old 10th Feb 2019, 6:45 pm   #10
g4wim_tim
In the time that it's apparently working ok I'd quickly check that the secondary AC voltages coming out of the mains transformer are as expected.
Anything out of the ordinary could be a clue as to the root cause, might be something as obvious as a wrong primary voltage setting !
Building and tinkering for over 50 years, from 807's to digital amateur TV.
g4wim_tim is offline
Old 12th Feb 2019, 11:49 pm   #11
G4YVM David
Turned out to be a breaking down if insulation primary to earth. Why is seemed to have a delayed reaction, who knows...
David, G4YVM.
Old 13th Feb 2019, 1:04 pm   #12
Keith
Keith's Avatar
Hi David,
Any chance of electrically isolating the transformer frame from the chassis (as long it can't be touched from outside, of course)?
Keith Yates - G3XGW
VMARS & BVWS member http://www.tibblestone.com/oldradios/Old_Radios.htm
Keith is offline
Old 16th Feb 2019, 7:04 pm   #13
Jon_G4MDC
Jon_G4MDC's Avatar
It might be worth taking that TXfrmr out and baking it for a long time at 50C or so.
Probably has damp in it.
Jon_G4MDC is online now
