Old 19th May 2018, 2:53 pm   #1
g4kjs Allen
Default R1155 Hetrodyne box problem and distorted audio --- Help!
Anyone got any ideas on solving this?
My R1155 was working OK until recently, but now when I switch on the Heterodyne Oscillator, it kills the HT power supply. The resistance between the Heterodyne Oscillator unit HT+ and chassis is now only 800 Ohms (when it should be 27k+ if I'm reading the circuit correctly). There is definitely no fault in the HT+ wiring to the box - so I need to get inside the heterodyne oscillator box to find out what's going on. Anyone know how to get in to it? the external wiring to the box is pretty fragile.
Also, I have another R1155 which works OK for an hour or so, then the audio gradually goes really horribly distorted.
Any help appreciated. Allen
g4kjs Allen is offline
Old 19th May 2018, 3:02 pm   #2
Station X
Station X's Avatar
Default Re: R1155 Hetrodyne box problem and distorted audio --- Help!
Did you manage to sort out your Sailor Transmitter?
https://www.vintage-radio.net/forum/...d.php?t=137986
It's nice to get some acknowledgement of advice offered.
Graham. Forum Moderator
Station X is offline
Old 19th May 2018, 3:48 pm   #3
Andrew2
Andrew2's Avatar
Chances are it's an HT decoupling cap gone s/c. C44 looks a likely candidate - the 1.5 K in series could well be giving the 800 ohms reading if it has 'cooked' over the years. Diligent inspection and a logical fault-finding approach should sort it. Take photos or make diagrams first just in care wires come adrift etc.
Andy G1HBE.
Andrew2 is offline
Old 19th Jun 2018, 6:27 pm   #4
cnpope20
Unless you are working from a different schematic with different component numbering, I think perhaps you didn't mean C44. In mine, C44 is one of the capacitors in the DF switching part of the receiver. Maybe you meant C12?
cnpope20 is offline
Old 20th Jun 2018, 9:27 am   #5
lesmw0sec
If I recall, the BFO is a bit awkward to work on. I expect that it would be necessary to disconnect the leads under the chassis and withdraw the BFO complete.
lesmw0sec is online now
Old 20th Jun 2018, 9:38 am   #6
CambridgeWorks
CambridgeWorks's Avatar
I wonder if the OP fixed his fault?
I have 3 R1155's and such information is always handy.
Rob
Apprehension creeping like a tube train up your spine - Cymbaline. Film More soundtrack - Pink Floyd
CambridgeWorks is online now
Old 20th Jun 2018, 10:17 am   #7
HamishBoxer
HamishBoxer's Avatar
It would be good if like the old TV forum I belonged everyone post fault/cure were possible.
HamishBoxer is offline
