16th Dec 2017, 2:35 pm | #1 |
Panasonic SG-5090 constant high volume noise
Hello all,
I have been trying to fix the mentioned music centre for a while. I could not get too much useful information about the issue neither the music centre, but I hope this forum will bring me luck. I got this music centre in the summer from an old guy who lives in a farm outside the city. The place was really dirty, so this piece of equipment was covered in dust, and I even found rat poison and sunflower seed hulls inside of it. He have not used it for a long while, so I did a deep cleaning before turning it on. It worked perfectly for about 50 hours of uptime, but then noise started. It is really hard to describe the issue since it is changing somehow... It is a high volume noise, that comes on immediately after turning the centre on, regardless of the audio input. Sometimes it is just random noise, but sometimes it has a pattern, like 5 impulses per second. It used to be the left channel, now both. Sometimes it changes when I touch the equipment's housing even so slightly (not to mention the circuits, or anything inside the housing), sometimes I need to use more force. And of course sometimes I turn it on and the noise is gone, and I have to wait a minute for the noise to come. These are the things I have tried:
Now I am at the point where my only idea is to check the power supply, and that is it. Do you have any ideas on this issue? What would you check? Keep in mind that I only have a cheap digital multimeter, so I cannot even get readings from the noise that reaches the speaker... (and I know, no household is a real household without an oscilloscope) Thanks in advance. |
17th Dec 2017, 7:23 am | #2 |
Re: Panasonic SG-5090 constant high volume noise
Welcome to the forum. It does sound like a dry joint or poor ground connection but could also be resistor noise but less likely so. Next is cleaning up any switches. You seem to have covered most of the likely culprits.
I non conducting prodder like a pencil is useful for tapping the PCB and components to try and find the source of the issue. Did this on a Marantz amp I had that had odd issue's; I'd fix one and another would pop up. Best of luck, Andy.
17th Dec 2017, 1:23 pm | #3 |
Hello and welcome to the forum. I have found with these sort of faults that a hairdryer as a heat source and a freezer aerosol can sometimes be very helpful. Warming the panel with the hairdryer and then cooling a small area at a time with the freezer spray can sometimes identify the component or dry joint etc. which is causing the problem. Good luck with your problem and have a happy Christmas. John.
