9th Dec 2017, 12:08 am | #41 |
Re: Restore an HMV 2127
To be entirely honest Mike I haven't understood your contributions other than at a superficial level, which is of course entirely due to my ignorance. Please don't be offended by my lack of acknowledgment to your posts. My hope is that as my knowledge grows as I resurrect this record player I come to properly appreciate the points you are making.
Nick. |
9th Dec 2017, 11:40 am | #42 |
Service Manual for Plessey Type D autochanger / HMV48700 deck
You can get a copy of the Service Manual for this deck from http://www.shopingathome.com/Circuit...0Lists/HMV.htm It is a comprehensive 41 page manual, with plenty of exploded views and covers; Operation, Maintenance, Adjustments, Faults and Spare Parts, and is available as a PDF download or in printed form/CD. Nick. |
9th Dec 2017, 12:22 pm | #43 |
That's very useful. Even so, we rarely come across them as they were mainly used on early 1950s period HMV Radiograms, Table Radiograms and I think one portable Record Player.
Edward. |
15th Dec 2017, 5:39 pm | #44 |
Other than the usual preliminary checks prior to powering up, do you think I should replace any of the caps in this machine? The smoothing can looks to be in good nick and I'll take it out of circuit to do a quick electrical test, but in the absence of service data, which I simply can't find for this player, I don't know if I should automatically replace any of the other caps.
It's very difficult to get a clear view of all the components and if I don't have to dismantle the machine to get at them it will be a bonus. Views? Thanks Nick |
15th Dec 2017, 5:53 pm | #45 |
The audio output g1 coupling capacitor at least, can you post an underneath view of the amplifier chassis?
Lawrence. |
15th Dec 2017, 6:27 pm | #46 |
Pics attached. Best I can do without dismantling the machine. I have taken plenty more if needed
N. |
15th Dec 2017, 7:31 pm | #47 |
That brown hunts capacitor that's connected between pins 1 & 9 of the ECL83 is the grid coupling capacitor to the audio output (pentode) section of that valve, that must be changed at least.
Check the HT electrolytic can for any signs of bulging of the can or the base also check the base and the tag rivets for any signs of chemical leakage, if all's ok it might survive. You should be able to reverse engineer a schematic for that, it would be good practice for you and also good for the forums collection of odd ball schematics (stuff not on Pauls downloads or DVD) The red and silver resistor and the electrolytic capacitor connected across it are the triode sections cathode bias resistor and bypass capacitor, the resistor is a 2.2k job, the 100 k resistor connected between the triode section anode (pin 1) and the pentodes screen grid (g2..pin 8) should be the triodes anode load, what looks like a 330k? resistor appears to be the pentodes g1 (pin 9) return resistor, the 470k (nearly shorting out to chassis) appears to be a feedback resistor from the pentodes anode (pin 6) via the anode tag of the sound output transformer to the triodes anode (pin1), both the screen grid and the HT feed to the sound output transformer seem to be connected to the HT filter capacitor, the big dog bone resistor is the HT filter resistor. Any errors then guilty as charged. Hope this will help you as to what's what circuit wise. Lawrence. Last edited by ms660; 15th Dec 2017 at 7:42 pm. |
15th Dec 2017, 9:11 pm | #48 |
Thanks Lawrence, I'll replace as recommended.
Happy to have a go at generating a schematic. If it were a 30s TRF I'd be very confident but I'm not quite as confident with this, although thankfully it looks quite straight forward. Let me have a go and perhaps someone would be good enough to look over it before I post it up Nick |
16th Dec 2017, 11:18 am | #49 | |
Edward. |
16th Dec 2017, 3:28 pm | #50 |
No offence taken Edward. I have no plans to attempt anything other than getting the player working. The question was of academic interest only.
Nick. |
17th Dec 2017, 2:33 am | #51 |
Is that mains voltage selector on the correct setting for your supply?
17th Dec 2017, 12:31 pm | #52 |
No it's not Boater Sam. You are as eagle-eyed as Nuvistor, who spotted it too
Nick |
22nd Dec 2017, 5:43 pm | #53 |
I managed to get a New Old Stock BSR-X5M cartridge with stylus and mounting clip (pics attached). I don't know how well is has been stored over the years but at first glance it looks clean and bright with no tarnishing to the metal. Is it safe to assume it will be OK or should I subject it to some sort of testing first?
Nick. |
22nd Dec 2017, 6:07 pm | #54 |
Ok, you're done...
I was going to suggest looking out for an ORIGINAL Ronette Stereo 105. I've got one and it does sound great at 6 - 8g tracking... Modern reproductions aren't too good in my experience. The BSR you've bought is great too, so don't worry. If you can't carefully work around the cartridge weight vs tracking weight differences, you may need some blue-Tac ballast perhaps. I don't know the deck at all so can't offer anything other than to check for dried out grease and lubrication of the motor, idler and main bearing bearings...
Best wishes, Dave |
22nd Dec 2017, 6:29 pm | #55 | |
I notice it has a high compliance stylus which would be great in the right arm, but I'm still not too sure how that old Plessey arm will cope with it. As I have said before, you are trying to defeat the Laws of Physics by trying to make this something it can never be.
Edward. |
22nd Dec 2017, 6:34 pm | #56 |
Thanks. Fingers crossed and all that.
According to the manual I obtained for this deck it is possible to adjust the tracking weight.... Adjustment Of Stylus Pressure "This may be carried out with a thin 4BA spanner on the hexagon C. Turning the hexagon clockwise (upwards) decreases the stylus pressure on the record and vice-versa. The recommended pressure measured at the stylus is 15-18 grammes with the 78 r.p.m. head and 11-13 grammes with the 33/45 r.p.m. head." I don't know if I can get the weight low enough for the BSR-X5M (it's much less than the existing cartridge), but at least I can give it a go. |
22nd Dec 2017, 10:16 pm | #57 | |
using the single screw hole that was used for the old one. You will probably be able to get the weight down to around the 5 gram mark, but my concern is that there will not be enough weight in the arm to trip the knock-off mechanism at the end of the record, and the arm will stick at that point. We'll see...... |
