20th Dec 2007, 11:20 pm | #1 |
Centrum 850V ac mains transformer
Hello.
I am restoring an old radio. It is a Centrum 850V made in Sweden, but some parts are missing. My problem is with the AC mains transformer. This component is missing and I dont know the output voltage of the secondary.This voltage is rectified by a 6X4 valve! Does anyone know the correct voltage and current for this secondary? I only know about the 6.3V / 2.5A. Here are 2 pictures to help identify this radio. I would also like to know the date of production of this radio. Best regards to all !! |
21st Dec 2007, 10:21 am | #2 |
Re: Centrum 850V ac mains transformer
The heater winding requirement is as you say 6.3 volt feeding heaters in parallel. Regards the HT winding, select a mains transformer that has a 250V-0-250V secondary or thereabouts. Just select one that will fit neatly on the chassis, a set like this is unlikely to draw an large current from the transformer.
Neil
21st Dec 2007, 6:37 pm | #3 |
Yes I would agree with Neil, it is likely to be 250-0-250, probabaly no more than 60mA rated (what type is the output valve?).
I would guess it is probabaly imeadiatley post war, say 1946-50. Ed |
21st Dec 2007, 8:41 pm | #4 |
Thankyou , this information is most helpfull !The output valve is a "6V6G". With your help this old radio will come alive again!
22nd Dec 2007, 6:06 pm | #5 |
The 6V6 is a standard valve for these sets (cheap and plentiful in the late 40's) and probably is not running near its max output so a 60mA transformer should be fine.
With a 6X4 there was often the temptation to run the rectifier from the main heater supply. If it's H-K insulation failed the results could be spectaular. You may find a transformer with 2, 6.3 V windings. The one with the thinnest wire was for the rectifier, the other one for the rest of the valve heaters. These were quite common. Ed |
23rd Dec 2007, 12:09 am | #6 |
I have all the information that i need to get the correct transformer for my radio!Thankyou and a mery christmas to all !
